Unable to add new attribute type.
brfcsdotcom
Post by brfcsdotcom » 23 Apr 2025, 08:05
I'm trying to add a new attribute type "Size" for our new store, and when I click the "+" icon I get an error:
Class "\Aimeos\Admin\JQAdm\Type\Attribute\Standard" not found
I'm on the latest Laravel version, 2025.04.1 according to Composer. I just did an update this morning to get the latest. I've cleared the cache and dumped the autoloader and still get the same error.
Re: Unable to add new attribute type.
Post by aimeos » 23 Apr 2025, 08:39
Unfortunately, we are not able to reproduce the issue. Can you please create a screen cast or post the full stack trace of the exception?
brfcsdotcom
Post by brfcsdotcom » 23 Apr 2025, 09:53
I've recorded a quick Loom video showing what I'm trying to do:
https://www.loom.com/share/09666ec70116 ... 013cb87b0b
brfcsdotcom
Post by brfcsdotcom » 23 Apr 2025, 09:57
If I go to the Types section of admin, there is a product type for size already (I did think it was an odd thing to be missing)
Feels like I'm trying to add the sizes the wrong way?
Post by aimeos » 23 Apr 2025, 10:18
The link in the admin item panel was wrong because all type panels have been merged into one in the latest version. The problem is fixed now and you can test yourself after executing:
composer req aimeos/ai-admin-jqadm:2025.04.x-dev
brfcsdotcom
Post by brfcsdotcom » 25 Apr 2025, 06:38
Thank you, I don't get that error any more.
However, when I go to add the attributes, there is already a product type for Size, but it doesn't show up in the list of options when creating attributes to assign to the variants
Screenshot 2025-04-24 at 22.21.36.png (14.8 KiB) Viewed 61518 times
Screenshot 2025-04-24 at 22.21.18.png (45.94 KiB) Viewed 61518 times
Post by aimeos » 25 Apr 2025, 06:54
A product type "size" makes no sense (there are "default", "select", "group", "event", "voucher"). What you need is a type for the domain "attribute"
brfcsdotcom
Post by brfcsdotcom » 27 Apr 2025, 19:39
I'm obviously missing something, size is listed on the Type settings page as a type in the product domain, but when I try to go and add an attribute in the product domain, it's not listed as something I can add.
Screenshot 2025-04-27 at 20.33.42.png (200.95 KiB) Viewed 61139 times
Screenshot 2025-04-27 at 20.22.23.jpg (224.69 KiB) Viewed 61139 times
brfcsdotcom
Post by brfcsdotcom » 27 Apr 2025, 20:10
If I look at one of the demo attributes that does appear in the drop down list, they don't have a type?
Screenshot 2025-04-27 at 21.08.19.png (135.91 KiB) Viewed 61136 times
Post by aimeos » 28 Apr 2025, 06:22
They have the type "attribute" and this is what you need to select, not "product"
