Issues with cms
hussain.h.ff32
Issues with cms
Post by hussain.h.ff32 » 06 May 2025, 18:23
When ever I do changes on cms it dose not change at all even after saving
Re: Issues with cms
Post by aimeos » 07 May 2025, 16:01
Did you click outside the content iframe before clicking on the Save button? If you click directly on the Save button, the content is not updated before sending the request to the server. This is one known issue with the used GrapesJS integration.
hussain.h.ff32
Re: Issues with cms
Post by hussain.h.ff32 » 08 May 2025, 15:52
yes i did and the image for example is showing in the cms but not in frontend
Screenshot 2025-05-08 174948.png (41.4 KiB) Viewed 380860 times
Screenshot 2025-05-08 175153.png (82.12 KiB) Viewed 380860 times
Re: Issues with cms
Post by aimeos » 10 May 2025, 14:39
Does the URL you try matches with the path you've entered in the field in the other tab and the route you can see executing "php artisan route:list"?
