Scheduler Job for anonymizing: anonymized adresses are not saved
claude27
Post by claude27 » 12 May 2025, 12:43
perhaps you can help me please.
I have created a scheduler job for anonymizing customer addresses (only payment, as events are sold and so delivery addresses are not needed) after 6 months.
The job is running but the addresses are not saved/ persisted in the database. What could be the reason?
Here is my code:
<?php
namespace Unterleitner\Sitepackage\Service;
use Aimeos\MShop;
use TYPO3\CMS\Scheduler\Task\AbstractTask;
class AnonymizeOrdersService extends AbstractTask
    public function execute(): bool
            try {
                $config = \Aimeos\Aimeos\Base::config();
                $context = \Aimeos\Aimeos\Base::context($config);
                $localeManager = \Aimeos\MShop::create($context, 'locale');
                $locale = $localeManager->bootstrap('default', 'de', 'default'); // site, lang, currency
                $context->setLocale($locale);
                $expiryDate = (new \DateTime())->modify('-6 months')->format('Y-m-d H:i:s');
                $productManager = MShop::create($context, 'product');
                $filter = $productManager->filter();
                $filter->add('product.type', '==', 'event');
                $filter->add('product.datestart', '<', $expiryDate);
                $products = $productManager->search($filter);
                $index_manager = \Aimeos\MShop::create( $context, 'index' );
                $index_manager->begin();
                $orderManager = MShop::create($context, 'order');
                foreach ($products as $product) {
                    $productId = $product->getId();
                    $orderFilter = $orderManager->filter();
                    $orderFilter->add(['order.product.productid' => $productId]);
                    $orders = $orderManager->search($orderFilter, ['order/address', 'order/product', 'order/service']);
                    if (!$orders->isEmpty()) {
                        foreach ($orders as $order) {
                            $order->setCustomerid(null);
                            $addresses = $order->getAddresses();
                            // Nur payment-Adressen anonymisieren
                            if (isset($addresses['payment'])) {
                                foreach ($addresses['payment'] as $address) {
                                    $address->setModified();
                                    $address->setFirstname('Anonym');
                                    $address->setLastname('Anonym');
                                    $address->setEmail('anonym@domain.nic');
                                    $address->setSalutation('');
                                    $address->setVatid('');
                                    $address->setCompany('');
                                    $address->setAddress1('');
                                    $address->setAddress2('');
                                    $address->setAddress3('');
                                    $address->setCity('');
                                    $address->setPostal('');
                                    $address->setState('');
                                    $address->setCountryid('');
                                    $address->setTelephone('');
                                $order->setAddresses($addresses);
                                $order->setModified();
                                $orderManager->save($order);
                return true;
            } catch (\Exception $e) {
                // Optional: Logging mit TYPO3 Logger
                return false;
This is the code of the task class:
<?php
namespace Unterleitner\Sitepackage\Scheduler\Task;
use TYPO3\CMS\Core\Utility\GeneralUtility;
use Unterleitner\Sitepackage\Service\AnonymizeOrdersService;
class AnonymizeOrdersSchedulerTask extends AbstractTask
        /** @var AnonymizeOrdersService $anonymizeOrdersService */
        $anonymizeOrdersService = GeneralUtility::makeInstance(AnonymizeOrdersService::class);
        $anonymizeOrdersService->execute();
        return true;
TYPO3 12, Aimeos 2024, PHP 8.3
Re: Scheduler Job for anonymizing: anonymized adresses are not saved
Post by aimeos » 13 May 2025, 05:10
Don't create the index manager (you don't use it) and open a DB transaction which you don't commit afterwards. All your changes are rolled back at the end of the task.
claude27
Post by claude27 » 14 May 2025, 07:24
Thank you very much! That was the solution.
Only I eventually have to extend the script to anonymize orders when the event/product is deleted and so no longer existing (we don't want do delete the events, we will archive them, but nobody knows what can happen...). But I will find a solution, I'm sure.
