Product import xml: Texts with html entities
Hi Aimeos-Team,
I exported products with version 2023.10.7 and try to importing in 2024.10.x-dev
The import finished successful but the texts for the products are as html entities. Is it a bug or is this not compatible for diff. versions?
- as html source code
- chrome-capture-2025-5-15 (1).png (34.33 KiB) Viewed 834815 times
- chrome-capture-2025-5-15.png (33.04 KiB) Viewed 834816 times
Thanks a lot!
Re: Product import xml: Texts with html entities
Are the HTML entities in the XML file or only after the import in the new system?
The entities are in the xml of the export:
<text.content><![CDATA[<ul><li> ...Thanks a lot!
It's most likely due to the $enc->xml() calls here which escapes the "<" and ">" characters:
https://github.com/aimeos/ai-controller ... rd.php#L33
The best solution might be to transform the HTML entities back here:
https://github.com/aimeos/ai-controller ... rd.php#L77
Ok, thank you.
I have replaced the entities in the xml with a editor now. I need this import only once.
Thanks a lot!
The content and attributes will be properly decoded in the 2025.10 release.
