Klarna Payment
stiller
Klarna Payment
Post by stiller » 19 May 2025, 14:14
hi there,
are there any plans to provide a payment plugin for widespread Klarna Services? Integration with Omnipay Mollie is not possible as this plugin is out of date and doesn't reflect changes to the Mollie API.
Cheers
Re: Klarna Payment
Post by aimeos » 20 May 2025, 06:41
We support all payment gateways through Omnipay and if one of the drivers is out of date or missing, you should update or implement it. This should be preferred over a direct integration using the Aimeos payment service provider interface.
stiller
Re: Klarna Payment
Post by stiller » 20 May 2025, 09:55
I've got your point.
I'd just like to stress that most of omnipay plugins are not well maintained and out of date.
it might well become a bottleneck to the further distribution of aimeos as it is a key factor in ecommerce to be able to provide a range of payment options.
e.g. the sofort plugin from the aimeos repositiory is not working anymore and there are no alternatives on github
does someone here can provide an up-to-date omnipay plugin for Klarna or Mollie?
that would be of great help.
Best
Re: Klarna Payment
Post by aimeos » 27 May 2025, 10:50
If you can give us more information about the problem in the Omnipay driver for Sofort payments, then we can fix it.
