translation question
crazyforester
Post by crazyforester » 17 Jun 2016, 09:41
Following tutorials it is easy to overwrite translation, I use the following script
plugin.tx_aimeos.settings.i18n.en.0 {
domain = client/html
string = address
trans = Addresses
but I couldn't find a way to overwrite translation of Salutation dropdown menu at checkout page
Is it possible to tell me the right string i.e. "string = adsress" as above.
Second, I see something very strange with Bulgarian version of aimeos.
If I have English version, then in Detail view I see "Product is available " - normal situation
but in Bulgarian version in Detail view I see in Bulgaria "Warehouse: name of warehouse, product is available"
could you help to find the reason
Thank you in advance
Re: translation question
Post by aimeos » 17 Jun 2016, 12:44
crazyforester wrote: but I couldn't find a way to overwrite translation of Salutation dropdown menu at checkout page
The translation domain is different. Use "client/code" instead of just "client" for all strings listed here:
https://github.com/aimeos/ai-client-htm ... /bg.po#L57
crazyforester wrote: If I have English version, then in Detail view I see "Product is available " - normal situation
In English, there's an "empty" translation for the warehouse codes:
https://github.com/aimeos/ai-client-htm ... en.po#L198
In Bulgarian there is a direct one:
https://github.com/aimeos/ai-client-htm ... bg.po#L204
You should change this in Transifex: https://www.transifex.com/aimeos/aimeos-core/
crazyforester
Post by crazyforester » 22 Jun 2016, 07:07
thank you for your reply, I tried with domain = client/code , but no success
Anyway, I changed translation in Transifex, because it were wrong
and downloaded and then uploaded the new bg.po file
but I see no changes.
Would you tell me what I have missed?
Thank you
Post by aimeos » 22 Jun 2016, 10:42
crazyforester wrote:thank you for your reply, I tried with domain = client/code , but no success
Which Aimeos version are you using? Aimeos 2.4.x requires "client/html/code" as domain.
crazyforester wrote: Anyway, I changed translation in Transifex, because it were wrong
For the bg.po file, a binary gettext file ("bg" only) has to be created:
msgfmt --statistics -c -o bg bg.po
We will update the translation and include it in the next release.
