After upgrade to 2024.10.4 - getRefItems doesn't return data
jafo66
Post by jafo66 » 19 May 2025, 21:21
Upgraded to 2024.10.4
We have been using the following code successfully for over a year. After upgrading this has stopped working.
$dbProduct = $productManager->get($productId, ['text', 'media', 'price', 'attribute']);
$long_description = $dbProduct->getRefItems('text', 'long', null)->first();
        if (isset($long_description)) {
            //Log::debug('description: ' . $description->get('text.content'));
            $product['text_long'] = $long_description->get('text.content');
        } else
            $product['text_long'] = "Description not provided";
Also, this variation has stopped working... any thoughts as to why?
$gameAttributeTypes = $dbProduct->getRefItems('attribute', 'default', 'default');
OR
$gameAttributeTypes = $dbProduct->getRefItems('attribute', null, null);
Re: After upgrade to 2024.10.4 - getRefItems doesn't return data
Post by aimeos » 20 May 2025, 07:01
Fetching list items has been moved to a decorator:
https://github.com/aimeos/aimeos-core/b ... ct.php#L13
If you replace the list of decorators with an own configuration and didn't add the new decorator names, the list items won't be fetched any more.
jafo66
Post by jafo66 » 20 May 2025, 13:46
Thanks... sorry for the newbie question, but should those settings go into the config/shop.php file or somewhere else?
Post by aimeos » 20 May 2025, 15:00
Only if you want to remove entries or overwrite settings with arrays completely. Otherwise, add them to the config files in your package because then, only the listed parts are added or overwritten.
