Index rebuild with more than one site
heural
Post by heural » 02 Jun 2025, 12:41
Hi Aimeos-Team,
if we add more than one site to the job "index/rebuild" only the "first" (maybe default) site is indexed in mshop_index_catalog and the other sites wont work anymore in the frontend (product not found).
As a workaround we added for each site a index-rebuild job.
Thanks a lot!
Re: Index rebuild with more than one site
Post by aimeos » 02 Jun 2025, 14:25
Which Aimeos version do you use?
heural
Post by heural » 03 Jun 2025, 10:38
Sorry, I forgot: 2024.10.x-dev. Just updated and tested.
Thanks a lot!
Post by aimeos » 03 Jul 2025, 09:22
Unfortunately, we can't reproduce the issue. The selected sites in the scheduler task are used to execute the job controller regardless if the task is executed in the frontend, by a cronjob or the job command executed on CLI. Do you have more information or can you add a bit of debugging to hunt down the problem?
