csv import: no media generation; srcset=""
columbo
Post by columbo » 07 Jul 2025, 19:22
for some reason, no preview images are generated druing/after a csv import. (Aimeos 2024.10)
But with a manual upload via the Aimeos admin backend they are.
4 medias in different sizes should be generated; so my shop.php
'mshop/media/manager/previews/product' =>
	['maxwidth' => 200, 'maxheight' => 200, 'force-size' => 0],
	['maxwidth' => 320, 'maxheight' => 320, 'force-size' => 0],
	['maxwidth' => 545, 'maxheight' => 545, 'force-size' => 0],
	['maxwidth' => 1050, 'maxheight' => 1050, 'force-size' => 0],
After manually uploading product images in the Aimeos backend, all product images are generated and displayed correctly in the shop on the category and detail pages:
<img loading="lazy" itemprop="image"
src="/aimeos/1.d/product/5/9/5973ad9f_a283c692_565006-my-product-abc.webp?v=20250707205419"
srcset="/aimeos/1.d/product/5/9/5973ad9f_a283c692_565006-my-product-abc.webp?v=20250707205419 200w,
/aimeos/1.d/product/c/2/c24603f2_a283c692_565006-my-product-abc.webp?v=20250707205419 320w,
/aimeos/1.d/product/e/2/e28f89f6_a283c692_565006-my-product-abc.webp?v=20250707205419 545w,
/aimeos/1.d/product/a/d/addfa35a_a283c692_565006-my-product-abc.webp?v=20250707205419 1050w"
sizes="(max-width:200px) 200px, (max-width:320px) 320px, (max-width:545px) 545px, 1050px"
alt="My Product ABC">
But after csv import (file including 'media.url', 'media.type' and 'media.label')
No medias are generated; only the original image provided by the csv import is displayed.
on catalog page:
src="/aimeos/prodimg/my-product-abc.jpeg"
srcset=""
also executed
php artisan aimeos:jobs "product/import/csv"
but no effect
What is missing, why are the medias are not generated by csv import?
Thank you!
Re: csv import: no media generation; srcset=""
Post by aimeos » 10 Jul 2025, 07:32
Can you check what happens here in your case, please?
https://github.com/aimeos/ai-controller ... #L218-L226
columbo
Post by columbo » 13 Jul 2025, 13:36
when updating an image (new image url in csv)
https://github.com/aimeos/ai-controller ... d.php#L223
executed
$refItem
    [available:protected] => 1
    [modified:protected] => 1
    [bprefix:protected] => media.
    [type:protected] =>
    [bdata:protected] => Array
            [.languageid] =>
            [media.siteid] => 1.
            [media.type] => prodimage
            [media.domain] => product
    [langid:Aimeos\MShop\Media\Item\Standard:private] =>
    [listItems:Aimeos\MShop\Media\Item\Standard:private] => Array
    [listRmItems:Aimeos\MShop\Media\Item\Standard:private] => Array
    [listMap:Aimeos\MShop\Media\Item\Standard:private] => Array
    [listMax:Aimeos\MShop\Media\Item\Standard:private] => 0
    [propItems:Aimeos\MShop\Media\Item\Standard:private] => Array
    [propRmItems:Aimeos\MShop\Media\Item\Standard:private] => Array
    [propMax:Aimeos\MShop\Media\Item\Standard:private] => 0
$list:
    [media.label] => My Product ABC
url:
$refItem after execution of:
$refItem = \Aimeos\MShop::create( $this->context(), 'media' )->scale( $refItem->setUrl( $url ), true );
    [type:protected] =>
            [.languageid] =>
            [media.url] => prodimg/my-product-abc.jpeg
when importing csv with same image url as before (image url remains unchanged)
https://github.com/aimeos/ai-controller ... d.php#L225
    [type:protected] =>
            [media.id] => 557643
            [media.ctime] => 2025-07-13 13:58:51
            [media.mtime] => 2025-07-13 13:58:51
            [media.editor] => aimeos:jobs
            [media.languageid] =>
            [media.mimetype] =>
            [media.previews] => Array
            [media.filesystem] => fs-media
            [media.status] => 1
            [cgroups] => 0
            [media.preview] => Array
            [.languageid] =>
url: prodimg/my-product-abc.jpeg
$refItem = \Aimeos\MShop::create( $this->context(), 'media' )->scale( $refItem->setUrl( $url ) );
    [type:protected] =>
            [media.mimetype] =>
            [media.url] => prodimg/565006 Frischk. Rollino bunter Pfeffer2.jpeg
            [media.status] => 1
            [cgroups] => 0
            [.languageid] =>
in both cases (new url and unchanged url) no medias are generated
Post by aimeos » 14 Jul 2025, 06:58
In case of unchanged URLs, no preview images should be generated so that's the intended behavior.
For new URLs, there should be preview images afterwards. Are there any errors in the logs? If not, can you please check in the media managerr what happens in that case?
columbo
Post by columbo » 14 Jul 2025, 19:18
thank you for your hin - found!
The reason is that the product images are in .jpeg format (and not in .jpg). Mimetype is not set for .jpeg
Is there an option to add .jpeg as supported filetype?
Post by aimeos » 16 Jul 2025, 08:13
You can change this entry for the file extension -> mime type relationship:
https://github.com/aimeos/aimeos-core/b ... ia.php#L53
Using this configuration:
https://aimeos.org/docs/2024.x/config/m ... extensions
