Create user in Backend with Editor
promptnet
Post by promptnet » 04 Sep 2025, 08:26
in our TYPO3/Aimeos Backend it is possible for an admin to create a new customer in Aimeos.
Also, the non-admin can see the list of customers but if he wants to create a customer a message shows up that there was an error but unfortunately without indicating what the problem is.
Aimeos: 24.10.5
TYPO3: 12.4.36
PHP: 8.2.28
Linux
Re: Create user in Backend with Editor
Post by aimeos » 07 Sep 2025, 10:50
What's logged in the Log panel after the error has occurred?
promptnet
Post by promptnet » 08 Sep 2025, 09:11
SQLSTATE[23000]: Integrity constraint violation: 1048 Column 'language' cannot be null
But there is a dropdown "Language" and it is set to German.
Post by aimeos » 02 Oct 2025, 10:41
This seems to be no general problem because in our test setups (TYPO3 12 + Aimeos 2024.10 and TYPO3 13 + Aimeos 2025.07) it works as expected. It also works when adding an address to the user in the "Addresses" sub-panel.
Did you overwrite this file?
https://github.com/aimeos/ai-admin-jqad ... r/item.php
promptnet
Post by promptnet » 06 Oct 2025, 14:01
No, that file is not overwritten.
Any other hints?
It seems that it must be related to rights for non-admins...
Post by aimeos » 15 Oct 2025, 17:41
If your user doesn't have admin rights, the site ID of the editor is different from the site ID of the created item.
In the next versions, a suitable error message will be shown.
promptnet
Post by promptnet » 16 Oct 2025, 08:44
Is there a way of bypassing that? E.g. hardcoding something or entering the siteid into the db for that user?
Any help is welcome.
Post by aimeos » 16 Oct 2025, 09:27
Make sure that the editor record uses the same value in "be_users.siteid" than the "mshop_locale_site.siteid" value of the site. Hope that helps.
promptnet
Post by promptnet » 23 Oct 2025, 06:35
That is the case...
