Price data not copied from Product to OrderProduct
columbo
Post by columbo » 21 Oct 2025, 20:19
I need to add products to the order/basket item.
Products including medias are added as expected, but the price domain is missing.
$manager = \Aimeos\MShop::create( $context, 'order/basket' );
$filter = $manager->filter()
    ->add( 'order.basket.customerid', '==', $context->user() )
    ->add( 'order.basket.id', '==', $basketid );
$basket = $manager->search( $filter )->first();
if($item = $basket->getItem())
    $product = \Aimeos\MShop::create($context, 'product')->get(	$prodid, ['text', 'media', 'price']);
    $orderProduct = \Aimeos\MShop::create($context, 'order/product')->create()->copyFrom($product);
    $item->addProduct($orderProduct);
    $manager->save($basket->setItem( $item ));
    Log::info(print_r($orderProduct, true));
'price' is added as data domain to the $product, but missing (not copied) in the $orderProduct
log output:
production.INFO: Aimeos\MShop\Order\Item\Product\Standard Object
    [available:protected] => 1
    [modified:protected] => 1
    [bprefix:protected] => order.product.
    [type:protected] =>
    [bdata:protected] => Array
            [.price] => Aimeos\MShop\Price\Item\Standard Object
                    [bprefix:protected] => price.
                    [type:protected] =>
                            [.currencyid] => EUR
                            [price.taxflag] => 1
                            [price.precision] => 2
                            [price.currencyid] => EUR
                            [price.siteid] => 1.
                    [precision:Aimeos\MShop\Price\Item\Standard:private] => 2
                    [tax:Aimeos\MShop\Price\Item\Standard:private] => 0
                    [listItems:Aimeos\MShop\Price\Item\Standard:private] => Array
                    [listRmItems:Aimeos\MShop\Price\Item\Standard:private] => Array
                    [listMap:Aimeos\MShop\Price\Item\Standard:private] => Array
                    [listMax:Aimeos\MShop\Price\Item\Standard:private] => 0
                    [propItems:Aimeos\MShop\Price\Item\Standard:private] => Array
                    [propRmItems:Aimeos\MShop\Price\Item\Standard:private] => Array
                    [propMax:Aimeos\MShop\Price\Item\Standard:private] => 0
            [order.product.siteid] => 1.
            [order.product.prodcode] => 4567
            [order.product.productid] => 123
            [order.product.type] => default
            [order.product.scale] => 1
            [order.product.target] =>
            [order.product.name] => My Product
            [order.product.mediaurl] => prodimg/My_Product.jpeg
    [attributesMap:Aimeos\MShop\Order\Item\Product\Base:private] =>
    [attrRmItems:Aimeos\MShop\Order\Item\Product\Base:private] => Array
thank you!
Re: Price data not copied from Product to OrderProduct
Post by aimeos » 22 Oct 2025, 08:10
Price calculation is more complex then just copying the first available price:
- https://github.com/aimeos/ai-controller ... #L347-L359
- https://github.com/aimeos/ai-controller ... se.php#L31
