Error during aimeos setup / upgrade
krzysiekp
Post by krzysiekp » 02 Dec 2025, 13:13
My composer.json
    "name": "laravel/laravel",
    "type": "project",
    "description": "The Laravel Framework.",
    "keywords": [
        "framework",
        "laravel"
    "license": "MIT",
    "require": {
        "php": "^8.4",
        "aimeos-extensions/new-ext": "dev-update_portal",
        "aimeos/aimeos-laravel": "^2024.10",
        "azuyalabs/yasumi": "^2.7",
        "barryvdh/laravel-snappy": "^1.0",
        "jschaedl/iban-validation": "^2.5",
        "laravel/framework": "^12.0",
        "laravel/jetstream": "^5.0",
        "phpoffice/phpspreadsheet": "^3.9",
        "picqer/php-barcode-generator": "^2.4",
        "rootinc/laravel-azure-middleware": "^0.9.10",
        "spatie/laravel-backup": "^9.0",
        "spatie/laravel-permission": "^6.10",
        "symfony/http-client": "^7.0",
        "symfony/mailgun-mailer": "^7.0"
    "require-dev": {
        "fakerphp/faker": "^1.9.1",
        "laravel/sail": "^1.0.1",
        "mockery/mockery": "^1.5",
        "nunomaduro/collision": "^8.0",
        "phpunit/phpunit": "^11.0",
        "spatie/laravel-ignition": "^2.9"
    "autoload": {
        "psr-4": {
            "App\\": "app/",
            "Database\\Factories\\": "database/factories/",
            "Database\\Seeders\\": "database/seeders/"
        "files": [
            "app/helpers.php"
    "autoload-dev": {
        "psr-4": {
            "Tests\\": "tests/"
    "scripts": {
        "post-autoload-dump": [
            "Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
            "@php artisan package:discover --ansi"
            "@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
        "post-create-project-cmd": [
            "@php artisan key:generate --ansi"
    "repositories": [
            "type": "composer",
            "url": "https://packages.aimeos.org/aimeoscom"
            "type": "path",
            "url": "./packages/*",
            "options": {
                "symlink": false
    "extra": {
        "laravel": {
            "dont-discover": []
    "config": {
        "optimize-autoloader": true,
        "preferred-install": "dist",
        "sort-packages": true
    "minimum-stability": "dev",
    "prefer-stable": true
DB version:
C:\xampp\mysql\bin>mysql -V
mysql  Ver 15.1 Distrib 10.4.32-MariaDB, for Win64 (AMD64), source revision c4143f909528e3fab0677a28631d10389354c491
PHP Version: 8.4.15
Error:
C:\xampp\htdocs\giftcards-portal-new>php8artisan aimeos:setup
Initializing or updating the Aimeos database tables for site "pl"
Migrating: \vendor\aimeos\aimeos-core\setup\AttributeMigrateKey.php
   Doctrine\DBAL\Exception\InvalidColumnDeclaration
  Column "type" has invalid type
  at vendor\doctrine\dbal\src\Exception\InvalidColumnDeclaration.php:16
     12▕ final class InvalidColumnDeclaration extends LogicException implements Exception
     13▕ {
     14▕     public static function fromInvalidColumnType(string $columnName, InvalidColumnType $e): self
     15▕     {
  ➜  16▕         return new self(sprintf('Column "%s" has invalid type', $columnName), 0, $e);
     17▕     }
     18▕ }
     19▕
  1   vendor\doctrine\dbal\src\Platforms\AbstractPlatform.php:206
      Doctrine\DBAL\Exception\InvalidColumnDeclaration::fromInvalidColumnType()
  2   vendor\doctrine\dbal\src\Exception\InvalidColumnType\ColumnLengthRequired.php:22
      Doctrine\DBAL\Exception\InvalidColumnType\ColumnLengthRequired::("Doctrine\DBAL\Platforms\MariaDBPlatform requires the length of a VARCHAR column to be specified")
Press any key to continue . . .
Re: Error during aimeos setup / upgrade
Post by aimeos » 02 Dec 2025, 13:59
The MariaDB version 10.4 is too old, please upgrade at least to MariaDB version 11.x.
krzysiekp
Post by krzysiekp » 05 Dec 2025, 11:37
I changed database to
mysql  Ver 8.4.7 for Win64 on x86_64 (MySQL Community Server - GPL)
and the same error
I will add that my current Laravel Aimeos version (database) is 2021.10 and I'm trying to update to 2024.10
Post by aimeos » 05 Dec 2025, 11:49
Please post the output of "SHOW CREATE TABLE mshop_attribute"
krzysiekp
Post by krzysiekp » 05 Dec 2025, 12:08
CREATE TABLE `mshop_attribute` (
  `id` int NOT NULL AUTO_INCREMENT,
  `siteid` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL,
  `key` varbinary(32) NOT NULL DEFAULT '',
  `type` varbinary(64) NOT NULL,
  `domain` varchar(32) COLLATE utf8mb4_unicode_ci NOT NULL,
  `code` varbinary(255) NOT NULL,
  `label` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL,
  `pos` int NOT NULL,
  `status` smallint NOT NULL,
  `mtime` datetime NOT NULL,
  `ctime` datetime NOT NULL,
  `editor` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL,
  PRIMARY KEY (`id`),
  UNIQUE KEY `unq_msatt_dom_sid_type_code` (`domain`,`siteid`,`type`,`code`),
  KEY `idx_msatt_dom_sid_stat_typ_pos` (`domain`,`siteid`,`status`,`type`,`pos`),
  KEY `idx_msatt_sid_status` (`siteid`,`status`),
  KEY `idx_msatt_sid_label` (`siteid`,`label`),
  KEY `idx_msatt_sid_code` (`siteid`,`code`),
  KEY `idx_msatt_sid_type` (`siteid`,`type`),
  KEY `idx_msatt_key_sid` (`key`,`siteid`)
) ENGINE=InnoDB AUTO_INCREMENT=172 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Post by aimeos » 06 Dec 2025, 10:34
What's the output of "composer show"?
krzysiekp
Post by krzysiekp » 08 Dec 2025, 09:02
C:\xampp\htdocs\giftcards-portal-new>php8 composer.phar show
aimeos-extensions/new-ext           dev-update_portal Aimeos new-ext extension
aimeos/ai-admin-graphql             2024.10.3         Aimeos Admin GraphQL API extension
aimeos/ai-admin-jqadm               2024.10.14        Aimeos VueJS+Bootstrap admin backend
aimeos/ai-admin-jsonadm             2024.10.3         Aimeos JSON admin API for backend
aimeos/ai-client-html               2024.10.7         Aimeos standard HTML frontend
aimeos/ai-client-jsonapi            2024.10.5         Aimeos frontend JSON REST API
aimeos/ai-cms-grapesjs              2024.10.8         Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend       2024.10.4         Aimeos business controller logic for frontend
aimeos/ai-controller-jobs           2024.10.9         Aimeos job controllers for long running tasks
aimeos/ai-laravel                   2024.10.4         Laravel adapter for Aimeos e-commerce integration
aimeos/aimeos-base                  2024.10.5         Aimeos base layer for abstracting from host environments
aimeos/aimeos-core                  2024.10.15        Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel               2024.10.4         Cloud native, API first Laravel eCommerce package with integrated AI for ultra-fast online shops, marketplaces and complex B2B projects
aimeos/macro                        1.0.2             Customize classes using closures
aimeos/map                          3.12.0            Easy and elegant handling of PHP arrays as array-like collection objects similar to jQuery and Laravel Collections
aimeos/upscheme                     1.2.0             Database schema upgrades made easy
azuyalabs/yasumi                    2.8.0             The easy PHP Library for calculating holidays
bacon/bacon-qr-code                 3.0.3             BaconQrCode is a QR code generator for PHP.
barryvdh/laravel-snappy             1.0.4             Snappy PDF/Image for Laravel
brick/math                          0.14.1            Arbitrary-precision arithmetic library
carbonphp/carbon-doctrine-types     3.2.0             Types to use Carbon in Doctrine
composer/pcre                       3.3.2             PCRE wrapping library that offers type-safe preg_* replacements.
dasprid/enum                        1.0.7             PHP 7.1 enum implementation
dflydev/dot-access-data             3.0.3             Given a deep data structure, access data by dot notation.
doctrine/dbal                       4.4.0             Powerful PHP database abstraction layer (DBAL) with many features for database schema introspection and management.
doctrine/deprecations               1.1.5             A small layer on top of trigger_error(E_USER_DEPRECATED) or PSR-3 logging with options to disable all deprecations or selectively for packages.
doctrine/inflector                  2.1.0             PHP Doctrine Inflector is a small library that can perform string manipulations with regard to upper/lowercase and singular/plural forms of words.
doctrine/lexer                      3.0.1             PHP Doctrine Lexer parser library that can be used in Top-Down, Recursive Descent Parsers.
dragonmantank/cron-expression       3.6.0             CRON for PHP: Calculate the next or previous run date and determine if a CRON expression is due
egulias/email-validator             4.0.4             A library for validating emails against several RFCs
enshrined/svg-sanitize              0.22.0            An SVG sanitizer for PHP
ezyang/htmlpurifier                 4.19.0            Standards compliant HTML filter written in PHP
fakerphp/faker                      1.24.1            Faker is a PHP library that generates fake data for you.
filp/whoops                         2.18.4            php error handling for cool kids
fruitcake/php-cors                  1.3.0             Cross-origin resource sharing library for the Symfony HttpFoundation
graham-campbell/result-type         1.1.3             An Implementation Of The Result Type
guzzlehttp/guzzle                   7.10.0            Guzzle is a PHP HTTP client library
guzzlehttp/promises                 2.3.0             Guzzle promises library
guzzlehttp/psr7                     2.8.0             PSR-7 message implementation that also provides common utility methods
guzzlehttp/uri-template             1.0.5             A polyfill class for uri_template of PHP
hamcrest/hamcrest-php               2.1.1             This is the PHP port of Hamcrest Matchers
intervention/gif                    4.2.2             Native PHP GIF Encoder/Decoder
intervention/image                  3.11.5            PHP Image Processing
jschaedl/iban-validation            2.6.0             A small library for validating International BankAccount Numbers (IBANs).
knplabs/knp-snappy                  1.5.1             PHP library allowing thumbnail, snapshot or PDF generation from a url or a html page. Wrapper for wkhtmltopdf/wkhtmltoimage.
laminas/laminas-diactoros           3.8.0             PSR HTTP Message implementations
laravel/fortify                     1.32.1            Backend controllers and scaffolding for Laravel authentication.
laravel/framework                   12.40.2           The Laravel Framework.
laravel/jetstream                   5.4.0             Tailwind scaffolding for the Laravel framework.
laravel/prompts                     0.3.8             Add beautiful and user-friendly forms to your command-line applications.
laravel/sail                        1.48.1            Docker files for running a basic Laravel application.
laravel/serializable-closure        2.0.7             Laravel Serializable Closure provides an easy and secure way to serialize closures in PHP.
league/commonmark                   2.8.0             Highly-extensible PHP Markdown parser which fully supports the CommonMark spec and GitHub-Flavored Markdown (GFM)
league/config                       1.2.0             Define configuration arrays with strict schemas and access values with dot notation
league/flysystem                    3.30.2            File storage abstraction for PHP
league/flysystem-local              3.30.2            Local filesystem adapter for Flysystem.
league/mime-type-detection          1.16.0            Mime-type detection for Flysystem
league/uri                          7.6.0             URI manipulation library
league/uri-interfaces               7.6.0             Common tools for parsing and resolving RFC3987/RFC3986 URI
maennchen/zipstream-php             3.2.0             ZipStream is a library for dynamically streaming dynamic zip files from PHP without writing to the disk at all on the server.
markbaker/complex                   3.0.2             PHP Class for working with complex numbers
markbaker/matrix                    3.0.1             PHP Class for working with matrices
microsoft/microsoft-graph           1.110.0           The Microsoft Graph SDK for PHP
mobiledetect/mobiledetectlib        4.8.09            Mobile_Detect is a lightweight PHP class for detecting mobile devices. It uses the User-Agent string combined with specific HTTP headers to detect the mobile environment.
mockery/mockery                     1.6.12            Mockery is a simple yet flexible PHP mock object framework
monolog/monolog                     3.9.0             Sends your logs to files, sockets, inboxes, databases and various web services
myclabs/deep-copy                   1.13.4            Create deep copies (clones) of your objects
nesbot/carbon                       3.10.3            An API extension for DateTime that supports 281 different languages.
nette/schema                        1.3.3             📐 Nette Schema: validating data structures against a given Schema.
nette/utils                         4.1.0             🛠  Nette Utils: lightweight utilities for string & array manipulation, image handling, safe JSON encoding/decoding, validation, slug or strong password generating etc.
nikic/php-parser                    5.6.2             A PHP parser written in PHP
nunomaduro/collision                8.8.3             Cli error handling for console/command-line PHP applications.
nunomaduro/termwind                 2.3.3             Its like Tailwind CSS, but for the console.
nyholm/psr7                         1.8.2             A fast PHP7 implementation of PSR-7
paragonie/constant_time_encoding    3.1.3             Constant-time Implementations of RFC 4648 Encoding (Base-64, Base-32, Base-16)
phar-io/manifest                    2.0.4             Component for reading phar.io manifest information from a PHP Archive (PHAR)
phar-io/version                     3.2.1             Library for handling version information and constraints
phpoffice/phpspreadsheet            3.10.2            PHPSpreadsheet - Read, Create and Write Spreadsheet documents in PHP - Spreadsheet engine
phpoption/phpoption                 1.9.4             Option Type for PHP
phpunit/php-code-coverage           11.0.11           Library that provides collection, processing, and rendering functionality for PHP code coverage information.
phpunit/php-file-iterator           5.1.0             FilterIterator implementation that filters files based on a list of suffixes.
phpunit/php-invoker                 5.0.1             Invoke callables with a timeout
phpunit/php-text-template           4.0.1             Simple template engine.
phpunit/php-timer                   7.0.1             Utility class for timing
phpunit/phpunit                     11.5.45           The PHP Unit Testing framework.
picqer/php-barcode-generator        2.4.2             An easy to use, non-bloated, barcode generator in PHP. Creates SVG, PNG, JPG and HTML images from the most used 1D barcode standards.
pragmarx/google2fa                  9.0.0             A One Time Password Authentication package, compatible with Google Authenticator.
psr/cache                           3.0.0             Common interface for caching libraries
psr/clock                           1.0.0             Common interface for reading the clock.
psr/container                       2.0.2             Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher                1.0.0             Standard interfaces for event handling.
psr/http-client                     1.0.3             Common interface for HTTP clients
psr/http-factory                    1.1.0             PSR-17: Common interfaces for PSR-7 HTTP message factories
psr/http-message                    2.0               Common interface for HTTP messages
psr/log                             3.0.2             Common interface for logging libraries
psr/simple-cache                    3.0.0             Common interfaces for simple caching
ralouphie/getallheaders             3.0.3             A polyfill for getallheaders.
ramsey/collection                   2.1.1             A PHP library for representing and manipulating collections.
ramsey/uuid                         4.9.1             A PHP library for generating and working with universally unique identifiers (UUIDs).
rootinc/laravel-azure-middleware    0.9.10            Azure Middleware Auth
sebastian/cli-parser                3.0.2             Library for parsing CLI options
sebastian/code-unit                 3.0.3             Collection of value objects that represent the PHP code units
sebastian/code-unit-reverse-lookup  4.0.1             Looks up which function or method a line of code belongs to
sebastian/comparator                6.3.2             Provides the functionality to compare PHP values for equality
sebastian/complexity                4.0.1             Library for calculating the complexity of PHP code units
sebastian/diff                      6.0.2             Diff implementation
sebastian/environment               7.2.1             Provides functionality to handle HHVM/PHP environments
sebastian/exporter                  6.3.2             Provides the functionality to export PHP variables for visualization
sebastian/global-state              7.0.2             Snapshotting of global state
sebastian/lines-of-code             3.0.1             Library for counting the lines of code in PHP source code
sebastian/object-enumerator         6.0.1             Traverses array structures and object graphs to enumerate all referenced objects
sebastian/object-reflector          4.0.1             Allows reflection of object attributes, including inherited and non-public ones
sebastian/recursion-context         6.0.3             Provides functionality to recursively process PHP variables
sebastian/type                      5.1.3             Collection of value objects that represent the types of the PHP type system
sebastian/version                   5.0.2             Library that helps with managing the version number of Git-hosted PHP projects
spatie/backtrace                    1.8.1             A better backtrace
spatie/db-dumper                    3.8.1             Dump databases
spatie/error-solutions              1.1.3             This is my package error-solutions
spatie/flare-client-php             1.10.1            Send PHP errors to Flare
spatie/ignition                     1.15.1            A beautiful error page for PHP applications.
spatie/laravel-backup               9.3.7             A Laravel package to backup your application
spatie/laravel-ignition             2.9.1             A beautiful error page for Laravel applications.
spatie/laravel-package-tools        1.92.7            Tools for creating Laravel packages
spatie/laravel-permission           6.23.0            Permission handling for Laravel 8.0 and up
spatie/laravel-signal-aware-command 2.1.1             Handle signals in artisan commands
spatie/temporary-directory          2.3.0             Easily create, use and destroy temporary directories
staabm/side-effects-detector        1.0.5             A static analysis tool to detect side effects in PHP code
symfony/clock                       7.4.0             Decouples applications from the system clock
symfony/console                     7.4.0             Eases the creation of beautiful and testable command line interfaces
symfony/css-selector                7.4.0             Converts CSS selectors to XPath expressions
symfony/deprecation-contracts       3.6.0             A generic function and convention to trigger deprecation notices
symfony/error-handler               7.4.0             Provides tools to manage errors and ease debugging PHP code
symfony/event-dispatcher            8.0.0             Provides tools that allow your application components to communicate with each other by dispatching events and listening to them
symfony/event-dispatcher-contracts  3.6.0             Generic abstractions related to dispatching event
symfony/finder                      7.4.0             Finds files and directories via an intuitive fluent interface
symfony/http-client                 7.4.0             Provides powerful methods to fetch HTTP resources synchronously or asynchronously
symfony/http-client-contracts       3.6.0             Generic abstractions related to HTTP clients
symfony/http-foundation             7.4.0             Defines an object-oriented layer for the HTTP specification
symfony/http-kernel                 7.4.0             Provides a structured process for converting a Request into a Response
symfony/mailer                      7.4.0             Helps sending emails
symfony/mailgun-mailer              7.4.0             Symfony Mailgun Mailer Bridge
symfony/mime                        7.4.0             Allows manipulating MIME messages
symfony/options-resolver            7.4.0             Provides an improved replacement for the array_replace PHP function
symfony/polyfill-ctype              1.33.0            Symfony polyfill for ctype functions
symfony/polyfill-intl-grapheme      1.33.0            Symfony polyfill for intl's grapheme_* functions
symfony/polyfill-intl-idn           1.33.0            Symfony polyfill for intl's idn_to_ascii and idn_to_utf8 functions
symfony/polyfill-intl-normalizer    1.33.0            Symfony polyfill for intl's Normalizer class and related functions
symfony/polyfill-mbstring           1.33.0            Symfony polyfill for the Mbstring extension
symfony/polyfill-php80              1.33.0            Symfony polyfill backporting some PHP 8.0+ features to lower PHP versions
symfony/polyfill-php83              1.33.0            Symfony polyfill backporting some PHP 8.3+ features to lower PHP versions
symfony/polyfill-php84              1.33.0            Symfony polyfill backporting some PHP 8.4+ features to lower PHP versions
symfony/polyfill-php85              1.33.0            Symfony polyfill backporting some PHP 8.5+ features to lower PHP versions
symfony/polyfill-uuid               1.33.0            Symfony polyfill for uuid functions
symfony/process                     7.4.0             Executes commands in sub-processes
symfony/psr-http-message-bridge     7.4.0             PSR HTTP message bridge
symfony/routing                     7.4.0             Maps an HTTP request to a set of configuration variables
symfony/service-contracts           3.6.1             Generic abstractions related to writing services
symfony/string                      8.0.0             Provides an object-oriented API to strings and deals with bytes, UTF-8 code points and grapheme clusters in a unified way
symfony/translation                 7.4.0             Provides tools to internationalize your application
symfony/translation-contracts       3.6.1             Generic abstractions related to translation
symfony/uid                         7.4.0             Provides an object-oriented API to generate and represent UIDs
symfony/var-dumper                  7.4.0             Provides mechanisms for walking through any arbitrary PHP variable
symfony/yaml                        7.4.0             Loads and dumps YAML files
tecnickcom/tcpdf                    6.10.1            TCPDF is a PHP class for generating PDF documents and barcodes.
theseer/tokenizer                   1.3.1             A small library for converting tokenized PHP source code into XML and potentially other formats
tijsverkoyen/css-to-inline-styles   2.3.0             CssToInlineStyles is a class that enables you to convert HTML-pages/files into HTML-pages/files with inline styles. This is very useful when you're sending emails.
vlucas/phpdotenv                    5.6.2             Loads environment variables from `.env` to `getenv()`, `$_ENV` and `$_SERVER` automagically.
voku/portable-ascii                 2.0.3             Portable ASCII library - performance optimized (ascii) string functions for php.
webonyx/graphql-php                 15.26.0           A PHP port of GraphQL reference implementation
Post by aimeos » 08 Dec 2025, 09:04
Looks OK at first sight but can you please try to update to 2025.10 instead as 2024.10 is end of life in 4 months.
krzysiekp
Post by krzysiekp » 08 Dec 2025, 09:50
The same error
     13▕ {
     15▕     {
     17▕     }
     18▕ }
     19▕
      Doctrine\DBAL\Exception\InvalidColumnType\ColumnLengthRequired::("Doctrine\DBAL\Platforms\MySQL84Platform requires the length of a VARCHAR column to be specified")
Below composer show
aimeos/ai-admin-graphql             2025.10.1         Aimeos Admin GraphQL API extension
aimeos/ai-admin-jqadm               2025.10.3         Aimeos VueJS+Bootstrap admin backend
aimeos/ai-admin-jsonadm             2025.10.1         Aimeos JSON admin API for backend
aimeos/ai-client-html               2025.10.3         Aimeos standard HTML frontend
aimeos/ai-client-jsonapi            2025.10.2         Aimeos frontend JSON REST API
aimeos/ai-cms-grapesjs              2025.10.2         Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend       2025.10.2         Aimeos business controller logic for frontend
aimeos/ai-controller-jobs           2025.10.5         Aimeos job controllers for long running tasks
aimeos/ai-laravel                   2025.10.1         Laravel adapter for Aimeos e-commerce integration
aimeos/aimeos-base                  2025.10.1         Aimeos base layer for abstracting from host environments
aimeos/aimeos-core                  2025.10.2         Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel               2025.10.1         Cloud native, API first Laravel eCommerce package with integrated AI for ultra-fast online shops, marketplaces and complex B2B projects
doctrine/dbal                       4.4.1             Powerful PHP database abstraction layer (DBAL) with many features for database schema introspection and management.
fruitcake/php-cors                  1.4.0             Cross-origin resource sharing library for the Symfony HttpFoundation
jschaedl/iban-validation            2.7.0             A small library for validating International BankAccount Numbers (IBANs).
laravel/framework                   12.41.1           The Laravel Framework.
laravel/sail                        1.50.0            Docker files for running a basic Laravel application.
nesbot/carbon                       3.11.0            An API extension for DateTime that supports 281 different languages.
nikic/php-parser                    5.7.0             A PHP parser written in PHP
phpunit/phpunit                     11.5.46           The PHP Unit Testing framework.
symfony/clock                       8.0.0             Decouples applications from the system clock
symfony/console                     7.4.1             Eases the creation of beautiful and testable command line interfaces
symfony/http-client                 7.4.1             Provides powerful methods to fetch HTTP resources synchronously or asynchronously
symfony/http-foundation             7.4.1             Defines an object-oriented layer for the HTTP specification
symfony/http-kernel                 7.4.2             Provides a structured process for converting a Request into a Response
symfony/options-resolver            8.0.0             Provides an improved replacement for the array_replace PHP function
symfony/string                      8.0.1             Provides an object-oriented API to strings and deals with bytes, UTF-8 code points and grapheme clusters in a unified way
symfony/translation                 8.0.1             Provides tools to internationalize your application
symfony/yaml                        7.4.1             Loads and dumps YAML files
webonyx/graphql-php                 15.27.1           A PHP port of GraphQL reference implementation
Post by aimeos » 08 Dec 2025, 09:59
The main problem seems to be:
But the VARCHAR should have a length of 64:
- https://github.com/aimeos/aimeos-core/b ... p.php#L196
- https://github.com/aimeos/aimeos-core/b ... #L217-L222
Can you check that please?
