Mandatory fields in checkout/address step ignored
MarcBlasig
Post by MarcBlasig » 27 Jan 2026, 09:29
Apologies if that question has been raised before or if my configuration is faulty, but I have set up "address2" as a mandatory field (and set the validation rule to ".+"). If I proceed to checkout a basket, in the "address" step my payment address is selected by a radio button. If I click on it, the full form fields are shown, with "address2" being empty and mandatory. Clicking on "Next" is then prohibited due to missing mandatory fields (as I would expect). However, if I don't click on the address, or even if I click it and afterwards collapse it again, I am allowed to proceed by clicking on "Next". How is that possible and how can I enforce the behaviour to not go any further unless all the mandatory fields are filled (it not just happens with address2).
plugin.tx_aimeos.settings.client.html.checkout.standard.address.billing.mandatory.0 = order.address.address2
plugin.tx_aimeos.settings.client.html.checkout.standard.address.delivery.mandatory.0 = order.address.address2
plugin.tx_aimeos.settings.client.html.common.address.payment.mandatory.3 = address2
Is what I have - maybe something is missing? But it seems to work as long as the fields are visible (which they are not all of the time).
Any help would be greatly appreciated!
Re: Mandatory fields in checkout/address step ignored
Post by aimeos » 27 Jan 2026, 09:41
Which Aimeos version do you use?
MarcBlasig
Post by MarcBlasig » 27 Jan 2026, 09:45
Thank you for replying :)
I am on the TYPO3 extension 25.10.3 and on TYPO3 12.4.42.
PS: Sorry for not adding those information in the first place. The reminder text is red, but pretty tiny so I overlooked it.
PPS: Regular registration for your forum seems broken, because of the Captcha. I can click on shoes all I want, it still claims I didn't do it right ;)
Post by aimeos » 29 Jan 2026, 08:30
How to set the form fields mandatory, optional or hidden is documented here:
https://aimeos.org/docs/latest/frontend ... orm-fields
If you do it like you did in TypoScript, it overwrites only the first configuration setting (firstname). Better use:
plugin.tx_aimeos.settings.client.html.common.address.payment.mandatory {
    0 = firstname
    1 = lastname
    2 = address1
    3 = address2
    4 = postal
    5 = city
    6 = languageid
    7 = email
MarcBlasig
Post by MarcBlasig » 29 Jan 2026, 08:56
Ok, I was just posting the "relevant" (meaning "address2") portion of the setup, I am already on
  0 = firstname
  1 = lastname
  2 = address1
  3 = address2
  4 = postal
  5 = city
  6 = email
7 = countryid
Also, that is working as intended everytime you actually "see" all the form fields, for example on the "my profile" page, and also in the checkout process when you actually display the full address data by clicking on the preselected radio button option.
The problem is that you can skip providing all the mandatory fields by just clicking "Next".
As a clarification, I want to implement the shop on a website with lots of existing frontend users as a new feature. So there is no registration process that demands "address2" to be set before entering the shop (which would be easiest as you can not save addresses without it as it is - the typoscript setup seems correct). I could of course write some middleware that checks if all the mandatory fields are set for the frontend user in shop context and prevent them from actually using the shop unless the fields are set, but to me, this seems like a bug that should be tackled officially as well.
Post by aimeos » 02 Feb 2026, 11:18
I see. An option would be to change the template and display all input fields for the payment address by default. Then, the values are passed to the backend and validated against your configuration.
MarcBlasig
Post by MarcBlasig » 02 Feb 2026, 12:59
Well sure, I guess I could remove the accordion functionality from the standard template, but that seems more like a workaround than a bugfix.
To that point a question regarding the documentation:
Templates#
The template views itself consist of HTML with alternative PHP syntax. It's also possible to use the native template engine of your framework or application, i.e. Blade for Laravel, Twig for Symfony and Fluid for TYPO3. Please have a look at the "Get started" section to find out more.
All standard templates are stored in the templates/client/html/ directory of the ai-client-html extension. [...]
It sounds like I can override "templates/client/html/checkout/standard/address-payment-body.php" with a Fluid template - Is that correct?
Post by aimeos » 02 Feb 2026, 14:54
MarcBlasig wrote: 02 Feb 2026, 12:59 Well sure, I guess I could remove the accordion functionality from the standard template, but that seems more like a workaround than a bugfix.
At the moment, yes. A better solution will need a bit of rewriting the checkout address client class.
MarcBlasig wrote: 02 Feb 2026, 12:59 It sounds like I can override "templates/client/html/checkout/standard/address-payment-body.php" with a Fluid template - Is that correct?
In theory, yes but you will notice some difficulties when you try to do that depending on the template.
