[SOLVED] Loading listItems (text attributes) of product does not respect context language
pla
Post by pla » 13 May 2026, 11:23
I have a problem loading attributes from a product in the given language.
I am using TYPO3 13.4.23 and AIMEOS:
- aimeos/aimeos-core: 2024.10.15
- aimeos/aimeos-typo3: 24.10.5
- aimeos/ai-typo3: 2024.10.5
- aimeos/ai-client-html: 2024.10.7
When I load a product via the product manager and try to load it's text attributes which are stored in multiple languages I expect to get only the translations given in the locale via the context (I made sure it is german => de) on instantiation of the product manager.
But I get ALL available translations.
Here is my code within a decorator on the detail page:
$productManager = \Aimeos\MShop::create($this->context(), 'product'); // context locale is german => de
$search = $productManager->filter();
$search->add('product.id', '==', $productId);
$product = $productManager->search($search, ['text'])->first();
DebugUtility:debug($product->getListItems('text', 'default', 'attributeTypeCode');
With this code I get ALL languages. Here's an image of a french value but it has a property .languageid = 'de' which seems that there is a check of the language but maybe it's broken or a bug?
Or do I have to add something into my code?
I hope I just oversee something and it is an easy fix.
Thanks and greetings
Pla
pla
Re: Loading listItems (text attributes) of product does not respect context language
Post by pla » 14 May 2026, 11:50
I have now built a complete custom initialization based on the AIMEOS source code I figured out so far and still get ALL translations:
// Getting the AIMEOS TypoScript settings
$configurationManager = GeneralUtility::makeInstance(ConfigurationManager::class);
$typoScriptService = GeneralUtility::makeInstance(TypoScriptService::class);
$typoScript = $configurationManager->getConfiguration(
	ConfigurationManagerInterface::CONFIGURATION_TYPE_FULL_TYPOSCRIPT
$typoScript = $typoScriptService->convertTypoScriptArrayToPlainArray($typoScript);
$settings = $typoScript['plugin']['tx_aimeos']['settings'];
// Initializing config, context and locale
$config = Base::config($settings);
$context = Base::context($config);
$localeManager = \Aimeos\MShop::create($context, 'locale');
$locale = $localeManager->bootstrap('default', 'de_DE', 'EUR');
// Apply config and set i18n as well as locale
$config->apply($locale->getSiteItem()->getConfig());
$context->setConfig($config);
$context->setI18n(Base::i18n([$locale->getLanguageId()], $config->get('i18n', [])));
$context->setLocale($locale);
// Load category tree, iterate them and make debug output
$catalogManager = \Aimeos\MShop::create($context, 'catalog');
$categories = $catalogManager->getTree(2, ['text'])->toList();
foreach($categories as $category) {
	DebugUtility::debug($category->getListItems('text', 'default'));
die(__FILE__.': '.__LINE__."\n");
And again I get ALL languages of the text attribute listItems as well as this weird property ".languageid" (having the de language as set in locale above) inside the listItem element where all other data starts with "text.XYZ" like in the screenshot of previous post.
Is this intended? How does this work in the e.g. list view of AIMEOS? How does AIMEOS know which language to display for the fields like name, short or long?
At the moment I have to iterate all listItems and check the language by myself
Post by aimeos » 21 May 2026, 13:53
Sorry for the long delay!
It's not a bug — it's by design.
When text items are loaded as references via $mgr->search($filter, ['text']), the internal code calls Text\Manager::filter() with no $default parameter (src/MShop/Common/Manager/ListsRef/Traits.php:112), which defaults to false. The language filter in Text\Manager::filter() (src/MShop/Text/Manager/Standard.php:52) only activates when $default !== false.
This means all language variants are always loaded for referenced items. This is intentional because:
- Admin panels need all translations
- Frontend templates pick the right language from the loaded set
- Items provide getName($langId) for language-aware access
- It's more efficient to load all variants once
Filter at the item level after loading (check $textItem->getLanguageId()), use $product->getName($langId), or use the frontend controller layer instead of direct manager access.
pla
Post by pla » 30 Jun 2026, 13:28
Thank you very much. At the moment I have added conditions to the languageid inside the template. Now I will check if I can replace loading the text items to use the frontend controller
pla
Post by pla » 15 Jul 2026, 14:03
Hi, I have now managed to take a further look into this problem.
I changed the code to use the frontend controller, but unfortunatelly I still get all translations of the text attribute "url".
Here is what my code looks now:
$category = \Aimeos\Controller\Frontend::create( $aimeosContext, 'catalog' )
	->uses( ['text'] )
	->get( $catId );
DebugUtility::debug($category->getListItems('text','default', 'url'));
I still get two translations even though I pass $aimeosContext which has the correct locale with the correct language (de) set. The result looks the same.
Or did I miss something? The ->getName($langId) is no option here because the value I want to get is not a direct attribute from the cateory like name but a text attributes which (as far as I know) I have to get by using the ->getListItems() method.
Would be nice if I could get a hint when I am still doing something wrong.
I would like to avoid iterating all listItems and compare the languageId of the items with the actual languageId because it's unnecessary, blows up the code and feels terrible wrong. Also I would have to do that in many cases.
Post by aimeos » 15 Jul 2026, 15:49
Don't use getListItems(), it't a low level method. Use:
- getName() for category/product names
- getRefItems(...) for all other texts
pla
[SOLVED] Re: Loading listItems (text attributes) of product does not respect context language
Post by pla » 24 Jul 2026, 15:45
I was now able to test this and it works.
Thank you very much!
