how to get back to the shopping cart
arunimadas
Hi aimeos I have an issue. How to get back to the shopping cart. please suggest me a proper solution.
- aa.png (60.82 KiB) Viewed 6542 times
Re: how to get back to the shopping cart
There's a button right of "Checkout" named "Back" where customers can get back to the last screen.
Regarding the "Related" subpart: You are right, the header shouldn't be displayed if nothing is available. Could you add a condition and open a PR on Github for this?
arunimadas
Hi Aimeos, thank you for this suggestion. I want to go the page where all the list of items are available, not to the last screen.Is there any way to add a button like 'continue shopping' after adding a item to the cart or busket??
You can copy the basket template to your custom Aimeos extension and add a link to the category you want your customers to be able to go back.
