Empty error when using authorize.net AIM payment in test
i have attached a screenshot, what should i do now? that's a really frustrating error...
running 2016.7.2 in laravel aimeos and ai-payments 2016.7.2. I ran it locally and I ran it as well on a testserver in the internet. It's an authorize.net test account and I used a test visa credit card, tried test mastercard as well.
I use php 7
some ideas where I should be heading now? where to search?
I use php 7
- error_authorize_net_aim_payment.jpg (62.43 KiB) Viewed 7673 times
Re: Empty error when using authorize.net AIM payment
I am still stuck with an error, but now I at least found it
the way to access the error message was this:
in file
the response message should be retrieved like this, if the response message is empty that is:
$response->getData()->messages->message->code->__toString()
$response->getData()->messages->message->text->__toString()[/code]
now I would create a pull request if i knew how. I really would.
The error reads like this:
at least now I am stuck with a proper error...
in file
ff-laravel/ext/ai-payments/lib/custom/src/MShop/Service/Provider/Payment/OmniPay.phpCode: Select all
at line 708 before
[code] throw new \Aimeos\MShop\Service\Exception( $response->getMessage() );$response->getData()->messages->message->code->__toString()
E00007
User authentication failed due to invalid authentication values.at least now I am stuck with a proper error...
hours later...
now I found in the interwebs that one has to regenerate the transaction Key. That is possible when logging in to authorize.net and then doing the change there, note: the answer to the security question for me was Simon and is called "Secret key" in the login creds they give you.
This did not solve my problem though (or i at least guess, that it was not part of the solution)
but something else...
is it eventually possible there is a mistake in the docs?
https://aimeos.org/docs/User_Manual/Adm ... ze.net_AIM
lists
this _seems_ to be wrong.
What I ended up doing when looking at the code I figured out there is:
so i added
in the configuration. This seems to work.
this changes the endpoint to apitest.authorize.... instead of the live one. basically, that is, i think, what should have been set with `authorizenet.testmode`
shit man, what, like 2 hours of my life for this.
there is as well:
i am not sure what it does. developerMode is what makes things work in sandbox
I found this note:
in
folder:
so maybe you can send test requests to the live account, maybe thats what it is good for.
lists
authorizenet.testmode (boolean, optional)
Use "1" for test payments without real money
developerModeCode: Select all
developerMode 1this changes the endpoint to apitest.authorize.... instead of the live one. basically, that is, i think, what should have been set with `authorizenet.testmode`
there is as well:
testModeI found this note:
// The test mode setting indicates whether or not this is a live request or a test requestCode: Select all
AIMAbstractRequest.phpCode: Select all
ff-laravel/vendor/omnipay/authorizenet/src/Message/AIMAbstractRequest.phpso maybe you can send test requests to the live account, maybe thats what it is good for.
