Upload PNG Problem
wassim.hattab
Upload PNG Problem
Post by wassim.hattab » 29 Jul 2016, 11:29
I'm trying to add catalogs in aimeos all is fine but when i try to add a media in the catalog i get Upload Failed (undefined) i tried to upload jpg and png images and i got same error.
wassim.hattab
Re: Upload Failed (undefined)
Post by wassim.hattab » 01 Aug 2016, 11:15
When i removed the debugger from the config all goes fine but when i upload a png image with transparency it replace the transparency with a color (white or yellow or black it depends on the image) does anyone faced this problem
wassim.hattab
Post by wassim.hattab » 01 Aug 2016, 13:12
This is a screen shot about the image i'm trying to upload and the result when i upload it via aimeos
wassim.hattab
Re: Upload PNG Problem
Post by wassim.hattab » 01 Aug 2016, 13:55
The problem was solved when adding this row in save function:
imagesavealpha($this->image, TRUE);
Post by aimeos » 01 Aug 2016, 14:55
This has been fixed three weeks ago and it should be already in the 2016.07.2 stable release
