virtual product - register customers
IOU42
Post by IOU42 » 29 Jul 2016, 18:41
We have some downloadable products and have added them to the catalogue.
The checkout process works well, except for user not being 'forced' to register during the check out.
As the download link in the email requires login, I would expect a required registration at check out. This is not showing as one of the options for the check out. I have configured below steps in config file shop.php:
'subparts'=>array( 'address', 'payment', 'summary', 'order', 'process' )
Or should this be enforced by adding 'auth' to the controller for one of the steps?
Is it possible to offer the check out without registering, obviously with the download link without the auth and available for some restricted time/downloads.
Can you please provide some guidance on how to achieve this?
Thanks!
System info:
Running Aimeos Laravel: 2022.10
Laravel Framework 9.52
Almalinux
PHP 8.1
Re: virtual product - register customers
Post by aimeos » 01 Aug 2016, 14:51
IOU42 wrote:Is it possible to offer the check out without registering, obviously with the download link without the auth and available for some restricted time/downloads.
Yes, because if a user has no account yet, there is one created by default at the end of the order process. Only make sure that you execute the job for the account creation e-mails.
IOU42
Post by IOU42 » 25 Aug 2016, 21:02
Thanks it works well now!
System info:
Almalinux
PHP 8.1
