uncaught reference error : d3 is not defined
jossnaz
Post by jossnaz » 15 Aug 2016, 20:42
see here:
http://imageshack.com/i/plqGocoAp
when accessing:
http://ffix.local/jqadm/search/dashboar ... lt&lang=en
now i had problems before:
laravel-package-f18/extadm-index-24-syn ... -t741.html
but i can without problems access the extadm area.
Re: uncaught reference error : d3 is not defined
Post by aimeos » 15 Aug 2016, 20:50
You've updated from Aimeos 2016.04 or earlier to 2016.07 and didn't replace the copies of the view files in the ./resources/views/vendor/shop/ directory.
jossnaz
Post by jossnaz » 18 Aug 2016, 21:43
i wish your docs were not plain wrong. I did indeed change the index.blade.php
but i did not copy the entire folder. Because it was not written to do so.
see here:
https://aimeos.org/docs/Laravel/Upgrade
now i copied the ENTIRE folder from the vendor directory, and it works.
But that is not according to the docs.
Post by aimeos » 19 Aug 2016, 16:17
Thanks for the hint, we've changed the documentation to make clear that the whole view directory must be copied.
