Not allowed to access configuration
jossnaz
Post by jossnaz » 27 Aug 2016, 23:05
i am trying to write my own config setting and read it from my custom body template.
Side question: i have defined my template body like this (shop.php):
  'client' => array(
    'html' => array(
      'checkout' => array(
        'standard' => array(
          'address' => array(
              'template-body' => array(
                __DIR__ . "/../ext/cmc-usa-salestax-by-state/client/html/templates/checkout/standard/address-billing-body-default.php"
i thought just leaving it in the right directory will load that template?! that is without specifying the directory in shop.php like i did above. That is for extensions. See here https://aimeos.org/docs/Developers/Html ... _templates
anyway:
when adding a config:
  'mshop' => array(
    'price' => array(
      'taxflag' => 0,
      'shoplocatedinusa' => 1,
and then accessing it in my address-billing-body-default.php results in
Not allowed to access "mshop/price/shoplocatedinusa" configuration
Re: Not allowed to access configuration
Post by aimeos » 28 Aug 2016, 00:59
jossnaz wrote: i thought just leaving it in the right directory will load that template?! that is without specifying the directory in shop.php like i did above. That is for extensions. See here https://aimeos.org/docs/Developers/Html ... _templates
That's right, it's enough to copy the template in your extension into the ./client/html/templates/checkout/standard/ directory. The only thing I'm currently thinking about is if it's necessary to have this in the manifest.php of your extension to ensure your extension templates are loaded after that of ai-client-html:
	'depends' => array(
		'aimeos-core',
		'ai-client-html',
jossnaz wrote: when adding a config:
  'mshop' => array(
    'price' => array(
      'taxflag' => 0,
Within the ai-client-html, you can only access configuration settings starting with "client/". This is enforced by the "Protect" config decorator and should prevent developers from trying to retrieve the database credentials and execute SQL in the templates :-)
jossnaz
Post by jossnaz » 28 Aug 2016, 04:12
seems too restrictive to me.
I hope i can access the config from my plugin... say, to check that the user has set the configuration correctly before proceeding to do stuff.
Post by aimeos » 28 Aug 2016, 09:57
If you want to add own configuration for your templates, please use the prefix "client/html/_..." instead. The "mshop/..." configuration settings are only for the data access layer in "./lib/mshoplib" of the Aimeos core.
