Payment provider status update
brunojti
Post by brunojti » 30 Aug 2016, 11:59
Hey there!
I was able to send the request to create a payment in my payment provider. YAY! :D :D :D
Now I can update the payment status via the provider, and I should provide a URL (So the provider can send post requests with status updates).
My question is:
Which url I should provide to receive these updates ( to trigger the `updateSync` function)?
How can I log to a text file the $params when I receive them via `updateSync`?
Re: Payment provider status update
Post by aimeos » 31 Aug 2016, 17:33
brunojti wrote:I was able to send the request to create a payment in my payment provider. YAY! :D :D :D
Great! :-)
brunojti wrote:Now I can update the payment status via the provider, and I should provide a URL (So the provider can send post requests with status updates).
My question is:
What did you've implemented? An Omnipay driver or an Aimeos payment service provider?
brunojti wrote:How can I log to a text file the $params when I receive them via `updateSync`?
In Aimeos you have a logger object in the context. If you use
$this->getContext()->getLogger()->log( '...' );
it will log an error message to the madmin_log table.
brunojti
Post by brunojti » 01 Sep 2016, 12:17
I am using a Custom Provider (based in Omnipay's code)
    public function process(\Aimeos\MShop\Order\Item\Iface $order, array $params = array())
        if (!isset($params['payment_type']) || empty($params['payment_type'])) {
            return $this->getPaymentForm($order, $params);
        return $this->processOrder($order, $params);
Post by aimeos » 02 Sep 2016, 08:09
The payment URLs are automatically generated depending on your environment and passed to the Omnipay driver:
https://github.com/aimeoscom/ai-payment ... y.php#L657
