Aimeos setup failed
Aimeos setup failed
I have a Synology linux server. There is one php for internal use and another php56 for users. I have installed composer based on php56 rather than php successfully. I have changed php to php56 in composer.json. But after I did composer update, the system got error message: fileinfo is missing in /etc/php/php.ini. It is still linked to php rather than php56. php.ini for php56 should be in /usr/local/etc/php56 and fileinfo is there already. Please check attachment for details. Any ideas? TIA.
Re: Aimeos setup failed
Sorry the first file was too big to be uploaded. Just reduced it and re-uploaded it.
- aimeos_with_php56_1.jpg (247.84 KiB) Viewed 6746 times
Seems to be more a question for the Synology forum how to add the PHP fileinfo module correctly.
I found the solution: php56 /usr/local/bin/composer update
