product photos
product photos
unfortunately I have some problems with configuration of display of product photos.
How can I instruct aimeos to only show one picture in the product list for each product, and not switching them every time one moves the mouse over?
And how can I show all with the product associated pictures in product detail as small preview icons? - There's only one picture shown; the others are only visible in the picture-zoom-window.
Thanks in advance!
best regards
Alexander
Thanks in advance!
best regards
Alexander
Re: product photos
That's easy. Overwrite the JS code for this feature and use an empty function:Alexander wrote: How can I instruct aimeos to only show one picture in the product list for each product, and not switching them every time one moves the mouse over?
https://github.com/aimeos/ai-client-htm ... os.js#L878
You can find more about this at https://aimeos.org/docs/Developers/Them ... Javascript
Can you post a screenshot?Alexander wrote:And how can I show all with the product associated pictures in product detail as small preview icons? - There's only one picture shown; the others are only visible in the picture-zoom-window.
Re: product photos
Thank you!aimeos wrote:That's easy. Overwrite the JS code for this feature and use an empty function:
That really seems to be easy, but I am missing something. In TYPO3 Template->Setup I tried these lines
AimeosCatalogList.init = function() {}
plugin.tx_aimeos.settings.AimeosCatalogList.init = function() {}
but both didn't work.
Do I have to put this somewhere else?
Now, I have attached a screenshot. The big and small red "image1" are the same - that's fine. But I think, the other images should be shown at the right side of "image1" to be selected and viewed in big. - The demo-shop here on aimeos.org does display all the images. But on my installation/configuration I have to click the big red image to get the zoom-window, and only there all the images are visible.aimeos wrote:Can you post a screenshot?Alexander wrote:And how can I show all with the product associated pictures in product detail as small preview icons? - There's only one picture shown; the others are only visible in the picture-zoom-window.
- aimeos.png (20.76 KiB) Viewed 15295 times
Re: product photos
Javascript is no TypoScript. You have to put the Javascript code into a .js file and add it to your page header if it's not already included.
Regarding the images in the detail view: Did you've changed one of the image-body-*.php templates? It seems like the location of the thumbnails in the HMTL doesn't correspond with the direction of the images set in the Javascript (it's configured as "data-dir" HTML tag attribute e.g. in https://github.com/aimeos/ai-client-htm ... t.php#L102).
Re: product photos
OK, thank you. I will try to do this.aimeos wrote:Javascript is no TypoScript. You have to put the Javascript code into a .js file and add it to your page header if it's not already included.
No. I didn't modify any files. Everything is just as installed. The only configuration I did, was in typo3-backend and typoScript.aimeos wrote:Regarding the images in the detail view: Did you've changed one of the image-body-*.php templates?
Unfortunately I can't find the file image-body-default.php, only a image-body-default.html.aimeos wrote:It seems like the location of the thumbnails in the HMTL doesn't correspond with the direction of the images set in the Javascript (it's configured as "data-dir" HTML tag attribute e.g. in https://github.com/aimeos/ai-client-htm ... t.php#L102).
In this file I find this line: <div class="catalog-detail-image" data-dir="horizontal">
If there's no evident and simple solution, I will leave it the way it is. - I don't want to torment you.
Thanks!
Re: product photos
You are using an Aimeos 2.4.x for TYPO3, aren't you? In the 16.x versions, the template files have been renamed to .php
There seems to be a problem with the Javascript. Maybe something is interfering with the Aimeos JS. If you have a look into the HTML source code, you will probably see that the HTML code for the images is there but they are displayed vertically. Maybe the JS console of your browser has some more hints.
Re: product photos
Yes, it's 2.4.3.aimeos wrote:You are using an Aimeos 2.4.x for TYPO3, aren't you? In the 16.x versions, the template files have been renamed to .php
You are absolutely right: the HTML-code is there, and the images are displayed vertically.aimeos wrote:There seems to be a problem with the Javascript. Maybe something is interfering with the Aimeos JS. If you have a look into the HTML source code, you will probably see that the HTML code for the images is there but they are displayed vertically. Maybe the JS console of your browser has some more hints.
I don't understand the code, but it seems a bit strange to me, that all functions are there twice. For instance "currentPosition" one with the comment "jQuery":
function(a, b) {
a.stopPropagation();
var c = 0 == g.first ? 0 : g.total - g.first;
s(b) && b.call(j, c);
return c
k = r.handle = function(a) {
return typeof m === K || a && m.event.triggered === a.type ? void 0 : m.event.dispatch.apply(k.elem, arguments)
}Should I try to update to the newest version?
Re: product photos
You can update to 2.4.7 (latest LTS) or 16.7.1 (latest stable).Alexander wrote:Should I try to update to the newest version?
Version 2.4.3 has issues and isn't supported any more.
Re: product photos
I just updated to 16.7.1. Now the images are visible. Great! Thank you.aimeos wrote:You can update to 2.4.7 (latest LTS) or 16.7.1 (latest stable).Alexander wrote:Should I try to update to the newest version?
Unfortunately the code for sending shop e-mails as text, not HTML and appending some text doesn't work anymore. Currently the code is:
plugin.tx_aimeos.settings.client.html.email.payment.default.subparts {
0 = text
plugin.tx_aimeos.settings.client.html.email.delivery.default.subparts {
0 = text
plugin.tx_aimeos.settings.i18n.en.0 {
domain = client/html
string = If you have any questions, please reply to this e-mail
Re: product photos
In the 16.x versions, "....default...." changed to "....standard...." and "client/html" to "client" only.
