Currency Swiss francs
derJu
Post by derJu » 22 Sep 2016, 14:11
Hi
i have add Currency Swiss francs set in the backend and frontend comes Fr instead of CHF
How can I change that is usually CHF?
That does not work
plugin.tx_aimeos.settings.i18n.de.0 {
  domain = client
  string = currency
  trans = CHF
best regards
derJu
Re: Currency Swiss francs
Post by aimeos » 22 Sep 2016, 14:37
The correct configuration would be
  domain = client/currency
  string = CHF
  trans = Fr
derJu
Post by derJu » 22 Sep 2016, 14:39
thank you , it works
best regards
derJu
