Delivery date in order process
derJu
Post by derJu » 30 Sep 2016, 07:58
how can i include a delivery date (custom value) in order process?
is this possible?
best regards
derJu
Re: Delivery date in order process
Post by aimeos » 02 Oct 2016, 13:53
Yes, that's not a big problem. Create a new service provider decorator and add the configuration for the value you want to add as additionally required value in the delivery checkout page: https://aimeos.org/docs/Developers/Libr ... figuration
You can use the existing decorators as examples:
https://github.com/aimeos/aimeos-core/t ... /Decorator
Here you can find how to configure your new decorator afterwards:
https://aimeos.org/docs/User_Manual/Adm ... decorators
derJu
Post by derJu » 07 Jun 2017, 07:49
hi,
i have a problem in the backend config of my own service provider.
i got an error when i will save it in backend see print screen.
hear ist the code of my own service decorator:
<?php
 * @copyright Metaways Infosystems GmbH, 2011
 * @copyright Aimeos (aimeos.org), 2015-2016
 * @package MShop
 * @subpackage Service
namespace Aimeos\MShop\Service\Provider\Decorator;
 * Ddate decorator for service provider.
 * @package MShop
class Swisspost
	extends \Aimeos\MShop\Service\Provider\Decorator\Base
	implements \Aimeos\MShop\Service\Provider\Decorator\Iface
	private $feConfig = array(
		'swisspost' => array(
			'code' => 'swisspost',
			'internalcode'=> 'swisspost',
			'label'=> 'PostPac Priority',
			'type'=> 'date',
			'internaltype'=> 'datetime',
			'default'=> '',
			'required'=> true,
     private $beConfig = array(
     		'swisspost.date' => array(
     			'code' => 'swisspost.date',
     			'internalcode'=> 'swisspost.date',
     			'type'=> 'date',
     			'default'=> '',
     			'required'=> true,
     public function getConfigFE( \Aimeos\MShop\Order\Item\Base\Iface $basket )
          $list = [];
		$feconfig = $this->feConfig;
         foreach( $feconfig as $key => $config ) {
             $list[$key] = new \Aimeos\MW\Criteria\Attribute\Standard( $config );
         return $list;
     public function checkConfigFE( array $attributes )
		return $this->checkConfig( $this->feConfig, $attributes );
	 * Checks the backend configuration attributes for validity.
	 * @param array $attributes Attributes added by the shop owner in the administraton interface
	 * @return array An array with the attribute keys as key and an error message as values for all attributes that are
	 * 	known by the provider but aren't valid
	public function checkConfigBE( array $attributes )
		$error = $this->getProvider()->checkConfigBE( $attributes );
		$error += $this->checkConfig( $this->beConfig, $attributes );
		return $error;
	 * Returns the configuration attribute definitions of the provider to generate a list of available fields and
	 * rules for the value of each field in the administration interface.
	 * @return array List of attribute definitions implementing \Aimeos\MW\Common\Critera\Attribute\Iface
	public function getConfigBE()
		$list = $this->getProvider()->getConfigBE();
		foreach( $this->beConfig as $key => $config ) {
		return $list;
	 * Checks if payment provider can be used based on the basket content.
	 * Checks for country, currency, address, scoring, etc. should be implemented in separate decorators
	 * @param \Aimeos\MShop\Order\Item\Base\Iface $basket Basket object
	 * @return boolean True if payment provider can be used, false if not
	public function isAvailable( \Aimeos\MShop\Order\Item\Base\Iface $basket )
		if( $basket->getLocale()->getLanguageId() === 'en' ) {
			return $this->getProvider()->isAvailable( $basket );
		return false;
has someone an idea?
LG - derju
Screen Shot 2017-06-07 at 09.42.23.png (12.81 KiB) Viewed 8694 times
Post by aimeos » 07 Jun 2017, 15:26
You've defined it as backend config instead of a frontend configuration.
derJu
Post by derJu » 08 Jun 2017, 07:29
thank's that's it!
next problem it show the code as label in frontend not the label from the config?
i tried:
# Example for overwriting translations
plugin.tx_aimeos.settings.i18n.en.0 {
  0 {
    domain = client
    string = Attributes
    trans = Filter
  1 {
    domain = client
    string = %1$d article
    trans {
      0 = %1$d
      1 = %1$d
   2 {
     domain = client/code
     string = swisspost
     trans = Lieferdatum
Post by aimeos » 08 Jun 2017, 20:52
The label is only for internal use because you can't localize it. Therefore, the code is used which you can translate but your translation array is wrong. You have one index to much and your TS config is equal to
plugin.tx_aimeos.settings.i18n.en.0.2.domain = client/code
but it must be
plugin.tx_aimeos.settings.i18n.en.2.domain = client/code
