Group product list by category names
Nils
Post by Nils » 16 Nov 2016, 15:46
I wanna list all products of 2 selected categories in the following way on a single list page:
Name of Cat 1
-> Product 1 of Cat 1
-> Product 2 of Cat 1
Name of Cat 2
-> Product 1 of Cat 2
-> Product 2 of Cat 2
How can I do that? I tried using 2 catalog list plugins. Each plugin got a different default category. But the second plugin displays the same category as the first plugin. I tried using both the flexform field "Default category if no parameter is available" and "TypoScript configuration" with "client.html.catalog.lists.catid-default = my category id".
Re: Group product list by category names
Post by aimeos » 17 Nov 2016, 15:05
There was a caching bug that prevented that use case. Can you please install and test this version?
https://aimeos.org/fileadmin/download/a ... 2-pre2.zip
Nils
Post by Nils » 21 Nov 2016, 12:43
It worked :)
Thank you for giving such a great support.
