State of 17.3.0
gilbertsoft
State of 17.3.0
Post by gilbertsoft » 14 Mar 2017, 15:32
Some questions:
- is this version a stable release now?
- what's the state of TYPO3 8 support?
Regards
Simon
Re: State of 17.3.0
Post by aimeos » 14 Mar 2017, 15:43
It's a beta release, so it's pretty stable but not officially ;-)
The first version marked as "stable" will be 17.4.0 but you can already use 17.3.0 for upcoming projects. TYPO3 8 is supported now and hopefully tested by as many developers as possible until Aimeos 17.4.0 arrives.
gilbertsoft
Re: State of 17.3.0
Post by gilbertsoft » 14 Mar 2017, 19:25
You marked it as stable in ext_conf, that's why I'm asking ;-)
I plan to update some dev and test systems to T3 8 to be prepared for the LTS release next month, so one more will test it 8-)
Re: State of 17.3.0
Post by aimeos » 14 Mar 2017, 21:32
gilbertsoft wrote:You marked it as stable in ext_conf, that's why I'm asking ;-)
Hm, seems we don't have the stable/beta flag for the TYPO3 extension really under control :-/
gilbertsoft wrote:I plan to update some dev and test systems to T3 8 to be prepared for the LTS release next month, so one more will test it 8-)
The biggest problem will be RealUrl for sure ...
gilbertsoft
Re: State of 17.3.0
Post by gilbertsoft » 20 Mar 2017, 19:07
I'll push a new build.xml with the extension state included, should solve the problem ;-) I'm using a similar version in my own T3 exts.
I'm testing now over a month with version 2 of realurl and never had problems. Do you have some real examples to make some progress there. My only problem was a missconfiguration of realurl, that I've already posted to issue 42. Please post them to the issue to have all together.
gilbertsoft
Re: State of 17.3.0
Post by gilbertsoft » 20 Mar 2017, 19:12
You already added the state to the build.xml as I saw :-)
