Frontend design changes
amit-vkaps
Post by amit-vkaps » 10 Sep 2021, 09:23
I want some changes in the Frontend design, so where I should do it. Can I add my changes to the vendor folder? If I can, so when we update the vendor then my changes will remain or it will be lost after updation. Please suggest?
Re: Frontend design changes
Post by aimeos » 11 Sep 2021, 09:03
No, don't make changes in the vendor folder as they will be overwritten after running "composer update". Instead, create your own Aimeos extension here: https://aimeos.org/extensions
If you use Laravel, there's documentation for creating new themes:
https://aimeos.org/docs/latest/laravel/themes/
Here you can find more and generic information about adapting the frontend:
https://aimeos.org/docs/latest/frontend ... te-themes/
