Media not showing in backend
harshithvemula
Re: Media not showing in backend
Post by harshithvemula » 17 Oct 2020, 10:35
Sorry for that i dont know how to do that. Can you explain me so that i can send
Post by aimeos » 17 Oct 2020, 10:39
Have a look at the records in the "mshop_media" table and there in the "preview" column. How does the field values for that image look like?
harshithvemula
Post by harshithvemula » 17 Oct 2020, 11:06
Unable to send attatchments.
"1":"data:image\/gif;base64,R0lGODdhAQABAIAAAAAAA...
Edit Edit
Copy Copy
Delete Delete
{"240":"preview\/e\/d\/ed5b3df5_2066981171.jpg","7...
Edit Edit
Copy Copy
Delete Delete
{"240":"https:\/\/demo.aimeos.org\/media\/2.jpg","...
Edit Edit
Copy Copy
Delete Delete
{"240":"https:\/\/demo.aimeos.org\/media\/3.jpg","...
Edit Edit
Copy Copy
Delete Delete
{"240":"https:\/\/demo.aimeos.org\/media\/4.jpg","...
Edit Edit
Copy Copy
Delete Delete
{"1":"data:image\/gif;base64,R0lGODdhAQABAIAAAAAA\...
Edit Edit
Copy Copy
Delete Delete
{"1":"data:image\/gif;base64,R0lGODdhAQABAIAAAPX13...
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
{"1":"https:\/\/demo.aimeos.org\/media\/1.jpg","25...
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
{"240":"https:\/\/demo.aimeos.org\/media\/1.jpg","...
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
{"240":"https:\/\/demo.aimeos.org\/media\/0-vouche...
Edit Edit
Copy Copy
Delete Delete
{"360":"https:\/\/demo.aimeos.org\/media\/stage.jp...
Edit Edit
Copy Copy
Delete Delete
{"1":"https:\/\/demo.aimeos.org\/media\/service\/p...
Edit Edit
Copy Copy
Delete Delete
{"0":"https:\/\/demo.aimeos.org\/media\/service\/d...
Edit Edit
Copy Copy
Delete Delete
Edit Edit
Copy Copy
Delete Delete
{"0":"https:\/\/demo.aimeos.org\/media\/service\/f...
Edit Edit
Copy Copy
Delete Delete
{"0":"https:\/\/demo.aimeos.org\/media\/service\/t...
Edit Edit
Copy Copy
Delete Delete
{"0":"https:\/\/demo.aimeos.org\/media\/service\/p...
Edit Edit
Copy Copy
Delete Delete
{"0":"https:\/\/demo.aimeos.org\/media\/service\/s...
Edit Edit
Copy Copy
Delete Delete
Post by aimeos » 17 Oct 2020, 11:11
The relative URLs are without leading slash:
So the problem could only be an old cache. Can you truncate the "madmin_cache" table please.
harshithvemula
Post by harshithvemula » 17 Oct 2020, 15:00
I have truncated the table "madmin_cache" and also cleared the cache using
php artisan config:cache
php artisan aimeos:clear
php artisan cache:clear
But no change.Still the images are notdisplayed
Post by aimeos » 19 Oct 2020, 16:17
I think, the slash added here is wrong:
https://github.com/aimeos/aimeos-larave ... lt.php#L49
Post by aimeos » 20 Oct 2020, 13:28
Can you please update to 2020.10.x-dev?
composer req aimeos/aimeos-laravel:2020.10.x-dev
Does it work for you after the update?
harshithvemula
Post by harshithvemula » 03 Nov 2020, 18:23
All the changes i have done are getting over rided when i update :roll: . Can you tell me how to stop it over riding so that i can update and check
Post by aimeos » 03 Nov 2020, 18:37
Don't change the Aimeos core files or the files in the official Aimeos extensions. Never!
Instead, create your own Aimeos extension and add your changed templates and new classes there:
- https://aimeos.org/docs/latest/developer/extensions/
- https://aimeos.org/extensions
harshithvemula
Post by harshithvemula » 04 Nov 2020, 17:07
I have updated to the "composer req aimeos/aimeos-laravel:2020.10.x-dev " version but still the problem is not solved. The broken images are still appearing in admin panel
