theme with multi-site does not work
mahmoud
Post by mahmoud » 01 Jun 2021, 21:52
windows 10: 64
PostgreSQL 9.6.15
Laravel Framework 8.37.0
PHP 7.4.16
"php": "^7.3|^8.0",
"aimeos/aimeos-laravel": "dev-master",
I modified the theme in my own extension everything works fine,
I switched to multi-site mode,
the theme of my own extension is no longer displayed, it displays the theme of aimeos extension. ai-client-html
codially
Re: theme with multi-site does not work
Post by aimeos » 03 Jun 2021, 08:52
In dev-master, we currently rework how different themes are included from extensions and how they can be selected in the backend. This isn't finished yet and if you need a stable version, then use 2021.04 instead until 2021.07 will be released.
mahmoud
Post by mahmoud » 25 Aug 2021, 22:39
Now My project configration:
"php": "^7.3|^8.0",
"aimeos/ai-cms-grapesjs": "2021.07.4",
"aimeos/aimeos-laravel": "~2021.07",
"fideloper/proxy": "^4.4",
"fruitcake/laravel-cors": "^2.0",
"guzzlehttp/guzzle": "^7.0.1",
"laravel/framework": "^8.12",
Now all my style changes in the templates extension are lost;
it displays the default aimeos themes.
Thank you.
Post by aimeos » 26 Aug 2021, 05:58
Please read this article how to create themes for Laravel in 2021.07+:
https://aimeos.org/docs/latest/laravel/themes/
mahmoud
Post by mahmoud » 27 Aug 2021, 03:46
Thank you very much for your answer,
I followed the steps it displays:
 "repositories": [{
        "type": "composer",
        "url": "https://packages.aimeos.org/aimeoscom",
        "devotheme1": {
            "type": "path",
            "url": "packages/devotheme1"
        "devotheme2": {
            "type": "path",
            "url": "packages/devotheme2"
        "devotheme3": {
            "type": "path",
            "url": "packages/devotheme3"
        "devotheme4": {
            "type": "path",
            "url": "packages/devotheme4"
composer req aimeos-themes/devotheme1
[InvalidArgumentException]
  Could not find a matching version of package aimeos-themes/devotheme1. Check the package spelling, your version constraint and that the package is available in a s
  tability which matches your minimum-stability (dev).
Post by aimeos » 27 Aug 2021, 06:40
Which files does your ./packages/devotheme1/ directory contain and can you post the ./packages/devotheme1/composer.json file?
mahmoud
Post by mahmoud » 27 Aug 2021, 13:25
	"name": "aimeos-themes/devotheme1",
	"description": "Aimeos devotheme1 extension",
	"keywords": ["aimeos", "extension"],
	"type": "aimeos-extension",
	"license": "LGPL-3.0",
	"prefer-stable": true,
	"minimum-stability": "dev",
	"require": {
		"php": "~7.1||~8.0",
	"autoload": {
		"psr-4": {
			"Aimeos\\MW\\": "lib/mwlib/src/MW/",
			"Aimeos\\MShop\\": "lib/mshoplib/src/MShop/",
			"Aimeos\\MAdmin\\": "lib/mshoplib/src/MAdmin/",
			"Aimeos\\Controller\\Common\\": "controller/common/src/Controller/Common/",
			"Aimeos\\Controller\\Frontend\\": "controller/frontend/src/Controller/Frontend/",
			"Aimeos\\Controller\\Jobs\\": "controller/jobs/src/Controller/Jobs/",
			"Aimeos\\Admin\\Jsonadm\\": "admin/jsonadm/src/Admin/Jsonadm/",
			"Aimeos\\Admin\\JQAdm\\": "admin/jqadm/src/Admin/JQAdm/",
			"Aimeos\\Client\\Html\\": "client/html/src/Client/Html/",
			"Aimeos\\Client\\Jsonapi\\": "client/jsonapi/src/Client/Jsonapi/"
		"classmap": [
			"client/html/src",
			"client/jsonapi/src",
			"admin/jqadm/src",
			"admin/jsonadm/src",
			"controller/common/src",
			"controller/frontend/src",
			"controller/jobs/src",
			"lib/custom/src",
			"ExtensionServiceProvider.php"
    "extra": {
        "laravel": {
            "providers": [
                "Aimeos\\devotheme\\ExtensionServiceProvider"
Post by aimeos » 27 Aug 2021, 14:17
Your "repositories" section is wrong, it must be:
    "repositories": [{
        "type": "composer",
    "devotheme1": {
            "type": "path",
    "devotheme2": {
            "type": "path",
    "devotheme3": {
            "type": "path",
    "devotheme4": {
            "type": "path",
mahmoud
Post by mahmoud » 27 Aug 2021, 21:08
I think I didn't explain it well.
In my laravel application i have 4 themes (devotheme1,devotheme2,devotheme3,devotheme4) in packages folder.
├── packages
│└── devotheme1
│ └─composer.json
│└── devotheme2
│ └─composer.json
│└── devotheme3
│ └─composer.json
│└── devotheme4
│ └─ composer.json
the 4 themes are generated by laravel theme 2021.x extension (https://aimeos.org/extensions)
The laravel application composer.json
    "name": "aimeos/aimeos",
    "description": "Aimeos shop system",
    "keywords": ["Aimeos", "e-commerce", "shop", "laravel", "distribution"],
    "license": "MIT",
    "type": "project",
    "repositories": [{
        "type": "composer",
        "devotheme1": {
            "type": "path",
        "devotheme2": {
            "type": "path",
        "devotheme3": {
            "type": "path",
        "devotheme4": {
            "type": "path",
    "require": {
        "php": "^7.2||^8.0",
        "composer-runtime-api": "^2.1",
        "aimeos/aimeos-laravel": "2021.07.*",
        "aimeos/ai-cms-grapesjs": "2021.07.*",
        "fideloper/proxy": "^4.0",
        "laravel/framework": "^6.20.12",
        "laravel/tinker": "^1.0",
        "laravel/ui": "^1.0"
    "require-dev": {
        "facade/ignition": "^1.4",
        "fzaninotto/faker": "^1.4",
        "mockery/mockery": "^1.0",
        "nunomaduro/collision": "^3.0",
        "phpunit/phpunit": "^8.0||^9.0"
    "config": {
        "optimize-autoloader": true,
        "preferred-install": "dist",
        "sort-packages": true
    "extra": {
        "laravel": {
            "dont-discover": []
    "autoload": {
        "psr-4": {
            "App\\": "app/"
        "classmap": [
            "database/seeds",
            "database/factories"
    "autoload-dev": {
        "psr-4": {
            "Tests\\": "tests/"
    "scripts": {
        "post-autoload-dump": [
            "Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
            "@php artisan package:discover --ansi"
            "@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
        "post-create-project-cmd": [
            "@php artisan key:generate --ansi",
            "App\\Composer::configure",
            "@php artisan migrate",
            "App\\Composer::setup",
            "App\\Composer::account",
            "App\\Composer::success"
        "post-update-cmd": [
            "@php artisan vendor:publish --tag=public --force"
The devotheme1 theme generated composer.json
	"require": {
	"autoload": {
		"psr-4": {
		"classmap": [
			"client/html/src",
			"admin/jqadm/src",
			"lib/custom/src",
    "extra": {
        "laravel": {
            "providers": [
Now when i do
display
[size=85][InvalidArgumentException]
require [--dev] [--dry-run] [--prefer-source] [--prefer-dist] [--prefer-install PREFER-INSTALL] [--fixed] [--no-suggest] [--no-progress] [--no-update] [--no-install] [--no-scripts] [--update-no-dev] [-w|--update-with-dependencies] [-W|--update-with-all-dependencies] [--with-dependencies] [--with-all-dependencies] [--ignore-platform-req IGNORE-PLATFORM-REQ] [--ignore-platform-reqs] [--prefer-stable] [--prefer-lowest] [--sort-packages] [-o|--optimize-autoloader] [-a|--classmap-authoritative] [--apcu-autoloader] [--apcu-autoloader-prefix APCU-AUTOLOADER-PREFIX] [--] [<packages>]...[/size]
Post by aimeos » 29 Aug 2021, 14:11
The "repositories" section of your root composer.json is invalid. Replace your section with the lines we've listed above.
