[solved] new extension not working
ai-otheriz
Post by ai-otheriz » 27 Apr 2020, 06:38
Dear aimeos,
i already create my own extension, then registering it on composer.json
"autoload": {
        "classmap": [
            "ext/<yourext>/lib/custom/src",
            "ext/<yourext>/controller/common/src",
            "ext/<yourext>/controller/frontend/src",
            "ext/<yourext>/controller/jobs/src",
            "ext/<yourext>/client/html/src",
            "ext/<yourext>/client/jsonapi/src",
            "ext/<yourext>/admin/html/src",
            "ext/<yourext>/admin/jsonadm/src"
execute "composer dump-autoload"
execute "php artisan aimeos:cache"
copy from "ai-client-html/client/html/templates/" to "myExt/client/html/templates"
but the website still referring to original template..am i missing some step ?
this is my setup
    "require": {
        "php": "^7.2",
        "fideloper/proxy": "^4.0",
        "laravel/framework": "^6.0",
        "laravel/tinker": "^1.0",
        "laravel/ui": "^1.0",
        "aimeos/aimeos-laravel": "~2019.10",
        "aimeos/ai-container": "dev-master"
ai-otheriz
Post by ai-otheriz » 28 Apr 2020, 06:46
I already solved it,
Unclear documentation should be trouble for the newbie user of this framework.(i also found it on other aimeos documentation)
I follow the document here https://aimeos.org/docs/Developers/Create_an_extension
at the first time i thought some of the text was just "explanation" not "how to instruction"
so the step is..
1. Create your own extension here https://aimeos.org/extensions/
2. Place your downloaded extension into folder "./ext/<your Ext>"
3. Copy all needed folder from original folder ai-****..to your extension folder(not all folder...folder list and location is on documentation)..
4. Copy manifest.php from any original folder(pick any)
5. Change all value on your copied manifest.php using the value on the documentation(depend, config, include,..etc)
Done..
I hope this help....
Re: [solved] new extension not working
Post by aimeos » 28 Apr 2020, 07:06
Usually, you don't have to copy and adapt the manifest.php file.
ai-otheriz
Post by ai-otheriz » 28 Apr 2020, 08:31
I want to try to install aimeos "2020.4"
but the extension creator max version only "2019.x"
is it OK to use that extension version ?
Post by aimeos » 28 Apr 2020, 22:12
We've updated our web site so you can create 2020 versions now:
mahmoud
Post by mahmoud » 11 Jun 2020, 01:02
Hello
the content of the folder: devoext (new extension created https://aimeos.org/extensions 11/06/2020)
the folder html does not exist in the admin folder
composer.json
   "classmap": [
            "database/seeds",
            "database/factories",
            "ext/devoext/lib/custom/src",
            "ext/devoext/controller/common/src",
            "ext/devoext/controller/frontend/src",
            "ext/devoext/controller/jobs/src",
            "ext/devoext/client/html/src",
            "ext/devoext/client/jsonapi/src",
            "ext/devoext/admin/html/src",
            "ext/devoext/admin/jsonadm/src"
[RuntimeException]
  Could not scan for classes inside "ext/devoext/admin/html/src" which does not appear to be a file nor a folder
thank you
Post by aimeos » 11 Jun 2020, 07:23
No, it's "admin/jqadm/src"
parmonov98
Post by parmonov98 » 06 Oct 2020, 13:05
aimeos wrote: 11 Jun 2020, 07:23 No, it's "admin/jqadm/src"
please, fix this in extenstion generator too.
Post by aimeos » 06 Oct 2020, 13:43
That's not a problem of the generated extensions.
The composer.json shipped with the generated extensions are fine.
Oscar
Post by Oscar » 17 Jul 2021, 10:34
ai-otheriz wrote: 28 Apr 2020, 06:46 I already solved it,
so the step is..
Done..
Thanks ai-otheriz!!!
i had same problem and solved with your tips!! :)
