JSON API - Get product list and attributes of products belong to the catalog
Kevin1596
Post by Kevin1596 » 18 Jan 2021, 10:06
AIMEOS Laravel 2020.10.*
Thank you so much for all your helps so far.
In my use case, I want to get the product list of a catalog and get all the possible attributes of all the products in that catalog as a filter for customer further filter rather than fetch all the attributes of the shop.
The problem is if I get the first 20 products with "include: attribute" and "f_catid" in the product Api call,
it will only return the attribute belong to the first 20 products, in some case there will be unique attributes belong to later products so I could not get it.
Is there anyway to make this use case possible without fetch all the attributes before hand but get the attributes belong to the products of a catalog?
Kevin1596
Re: JSON API - Get product list and attributes of products belong to the catalog
Post by Kevin1596 » 18 Jan 2021, 10:52
How could I calculate the total product of each attribute of catalog with json api as the image follow?
Screen Shot 2021-01-18 at 5.50.23 PM.png (78.95 KiB) Viewed 4797 times
Post by aimeos » 19 Jan 2021, 10:52
Use the attribute endpoint of the JSON REST API to get all attributes:
https://aimeos.org/docs/latest/frontend ... ted-search
