Extension generator site is generating corrupt zip file for extensions
dheeraj
Post by dheeraj » 31 May 2021, 07:26
Laravel : 8.40
Aimeos : 2021.04
PHP Version : 7.4.18
Environment : Windows
The site https://aimeos.org/extensions is generating corrupt zip file for Aimeos extensions.
Kindly fix it as soon as possible.
Thank you.
Re: Extension generator site is generating corrupt zip file for extensions
Post by aimeos » 31 May 2021, 07:34
Corrupt in which way? I've created a new extension (2021.x) and the .zip file can be extracted without problems
dheeraj
Post by dheeraj » 31 May 2021, 09:23
I am getting this error whenever i open the downloaded extension zip file.
Screenshot 2021-05-31 144946.png (13.69 KiB) Viewed 7480 times
Post by aimeos » 31 May 2021, 09:27
Does this also occur if you create a new one?
dheeraj
Post by dheeraj » 31 May 2021, 10:06
create a new one ??
Do you mean when i create a new zip file on my computer ?? No problem for other zip files or newly created zip files.
Do you mean when i create a new zip file for aimeos extension on my computer ?? I don't know how to do that.
I just downloaded the zip file generated by the aforementioned site and when i tried to open or extract it, it resulted in the error.
Post by aimeos » 31 May 2021, 11:09
Use the form at https://aimeos.org/extensions to generate a new Zip file and see if it's corrupt again. Maybe it only was a network defect.
dheeraj
Post by dheeraj » 31 May 2021, 11:21
Still getting the same corrupted zip file (also changed package type field in form).
