Search produc by codes
AmzoooJibal
Post by AmzoooJibal » 19 Jul 2021, 13:53
i dont understand why this method not working as expected:
          $codes = [
                0 => "demo-article",
                1 => "demo-selection-article-2",
                2 => "demo-selection-article-1",
            $config = $context->getConfig();
            $domains = [
                'attribute', 'media', 'media/property', 'price', 'product', 'text', 'stock', 'supplier'
            $domains = $config->get('client/html/catalog/domains', $domains);
            $domains = $config->get('client/html/catalog/detail/domains', $domains);
            $products = \Aimeos\Controller\Frontend::create($context, 'product')
                ->compare('==', 'product.code', $codes)
                ->slice(0, count($codes))
                ->uses($domains)->search();
           dd($products);
The result is one product (demo-article) :
Aimeos\Map {#2844 ▼
  #list: array:1 [▼
    1 => Aimeos\MShop\Product\Item\Standard {#2644 ▼
      -date: "2021-07-19 13:52:00"
      -prefix: "product."
      -available: true
      -modified: false
      #bdata: array:21 [▼
        "product.id" => "1"
        "product.siteid" => "1."
        "product.type" => "default"
        "product.code" => "demo-article"
        "product.label" => "Demo article"
        "product.url" => "Demo-article"
        "product.datestart" => null
        "product.dateend" => null
        "product.status" => "1"
        "product.ctime" => "2021-06-17 11:10:00"
        "product.mtime" => "2021-06-30 15:02:05"
        "product.editor" => "127.0.0.1"
        "product.target" => ""
        "product.dataset" => ""
        "product.scale" => "1"
        "product.config" => []
        "product.rating" => "0.00"
        "product.ratings" => "0"
        ".supplier" => array:1 [▶]
        ".stock" => array:1 [▶]
        ".date" => "2021-07-19 13:52:00"
      -listItems: array:4 [▶]
      -listRefItems: array:4 [▶]
      -listRmItems: []
      -listPrepared: false
      -listRmMap: []
      -listMap: []
      -listMax: 19
      -propItems: []
      -propRmItems: []
      -propMax: 0
  #sep: "/"
Re: Search produc by codes
Post by aimeos » 19 Jul 2021, 20:24
"demo-selection-article-1" and "demo-selection-article-2" are variant articles of a selection product and haven't been added to any category. Thus, the frontend controller don't return them as products.
AmzoooJibal
Post by AmzoooJibal » 30 Jul 2021, 15:52
Ah ok thank you, in the json admin api how i can get the same rules ? when i try with this url:
http://www.test.com/admin/default/jsonadm/product?filter%5B%7C%7C%5D%5B0%5D%5B%3D%3D%5D%5Bproduct.id%5D=&filter%5B%7C%7C%5D%5B1%5D%5B%3D~%5D%5Bproduct.code%5D=&filter%5B%7C%7C%5D%5B2%5D%5B%3D~%5D%5Bproduct.label%5D=&fields%5Bproduct%5D=product.id%2Cproduct.code%2Cproduct.label&page%5Boffset%5D=0&page%5Blimit%5D=25&sort=product.label&include=product
How i can get like the front result ? where i can get all rules ?
Post by aimeos » 01 Aug 2021, 08:56
To get several products by code including the domains, you need a filter like this:
filter[||][0][==][product.code]=prodcode1&filter[||][1][==][product.code]=prodcode2&filter[||][2][==][product.code]=prodcode3&include=attribute,media,price,...
AmzoooJibal
Post by AmzoooJibal » 02 Aug 2021, 13:38
thank you for your response.
the search is well documented in the documentation except how to filter in relation in my case how i can filter product that is attached to a category ?
as you said in frontend only the product that is attached to a category is searched, so in admin json api i need to do the same filter in product endpoint to get only the product that is attached to a category
Post by aimeos » 03 Aug 2021, 13:37
Retrieving products by category is descriped here:
https://aimeos.org/docs/latest/frontend ... y-category
