Product decorator did not work
IvanIgniter
Post by IvanIgniter » 01 Dec 2021, 08:16
Can you please help in my code to work with product decorator which will display the 'barcode' column from product table which was added after I extend in ext\ai-laravel\lib\custom\setup\default\schema\product.php. I was working fine in the database after I run php artisan aimeos:setup.
I would like to display the value of the product.barcode column in the product edit page based on
https://aimeos.org/docs/2021.x/models/e ... -decorator
I have made \ext\ai-laravel\lib\custom\src\MShop\Product\Manager\Decorator\Myproject.php
<?php
namespace Aimeos\MShop\Product\Manager\Decorator;
class Myproject extends \Aimeos\MShop\Common\Manager\Decorator\Base
    private $attr = [
        'barcode' => [
            'code' => 'barcode',
            'internalcode' => 'mpro."barcode"',
            'label' => 'Barcode',
            'type' => 'string',
            'internaltype' => \Aimeos\MW\DB\Statement\Base::PARAM_STR,
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
    public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
\ext\ai-laravel\config\mshop.php
<?php
return [
    'product' => [
        'manager' => [
            'decorators' => [
                'local' => ['Myproject']
I tried to display the value of barcode in \ext\ai-admin-jqadm\admin\jqadm\src\Admin\JQAdm\Product\Standard.php
but it just display the default value because it returns null value.
public function get() : ?string
		$view = $this->getObject()->addData( $this->getView() );
		try
			if( ( $id = $view->param( 'id' ) ) === null )
				$msg = $this->getContext()->translate( 'admin', 'Required parameter "%1$s" is missing' );
				throw new \Aimeos\Admin\JQAdm\Exception( sprintf( $msg, 'id' ) );
			$manager = \Aimeos\MShop::create( $this->getContext(), 'product' );
			$view->item = $manager->get( $id, $this->getDomains() );
			dd($view->item->get( 'barcode', '<default value1>' ));
			dd($view->item->get( 'product.barcode', '<default value2>' ));
			dd($view->item->get( 'mpro.barcode', '<default value3>' ));
			$view->itemData = $this->toArray( $view->item );
			$view->itemBody = parent::get();
		catch( \Exception $e )
			$this->report( $e, 'get' );
		return $this->render( $view );
Or in
\ext\ai-admin-jqadm\admin\jqadm\templates\product\item-standard.php would still return a null value.
$enc->attr( $this->get( 'barcode' ) )
I have follow the instruction from the documentation in https://aimeos.org/docs/latest/models/extend-managers/
but I have no luck. Please instruct how to make it work correctly?
Note: I am using laravel 6.x, PHP 7.4, Docker desktop/Ubuntu and the Aimeos 2021 - https://github.com/aimeos/aimeos-laravel
IvanIgniter
Re: Product decorator did not work
Post by IvanIgniter » 02 Dec 2021, 01:15
I have figure it out.
It should have be in \ext\ai-admin-jqadm\lib\custom\src\MShop\Product\Manager\Decorator\Myproject.php
Thank you
