How can I create a new field in the "BASIC" section of the product card?
santfather
Post by santfather » 02 Feb 2022, 11:03
Laravel version: 8.80
Aimeos version: 2021.10
PHP version: 8.0.8
WIN user
How can I create a new field in the "BASIC" section of the product card (in the admin panel), so that I can then filter products by this field?
I duplicated the code of one component. based on it, I want to make my own field by which I can filter products. Where and in what area do you need to make changes?
Re: How can I create a new field in the "BASIC" section of the product card?
Post by aimeos » 02 Feb 2022, 17:08
First, you need to add a new column to the mshop_product table and create a decorator for the product manager so it will know how to save and search your new property:
https://aimeos.org/docs/latest/models/extend-managers/
Then, you can use that property in the list template:
- https://github.com/aimeos/ai-admin-jqad ... #L530-L548
- https://github.com/aimeos/ai-admin-jqad ... #L644-L668
- https://github.com/aimeos/ai-admin-jqad ... d.php#L512
Add the property in the item template too so editors can change it:
https://github.com/aimeos/ai-admin-jqad ... #L343-L357
That's all.
santfather
Post by santfather » 10 Feb 2022, 13:28
I took "product.code" as a basis
and added my "product.modelfamily" field to the files:
1. aimeos\vendor\aimeos\ai-admin-jqadm\admin\jqadm\templates\product\list-standard.php
2. aimeos\vendor\aimeos\ai-admin-jqadm\admin\jqadm\templates\product\item-standard.php
3. aimeos\vendor\aimeos\ai-admin-jqadm\admin\jqadm\templates\product\item-selection-standard.php
4. aimeos\vendor\aimeos\aimeos-core\lib\mshoplib\config\mshop\product.php
5. aimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Product\Item\Iface.php
6. aimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Product\Item\Standard.php
7. aimeos\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Product\Manager\Standard.php
after all the manipulations, I see a new column and the values in it.
moreover, sorting in descending and ascending order works, as well as searching by ID
BUT, I can't enter data (correct, add or delete) in the product.modelfamily field from the admin panel. Only through the database. although a message about a successful operation appears
Post by aimeos » 11 Feb 2022, 14:27
Don't change the files in the Aimeos core or the Aimeos extensions!
You will loose all your changes when running "composer update"!
Instead, create your own extension:
https://aimeos.org/docs/latest/developer/extensions/
Implement a decorator to extend the product manager:
Copy and adapt the product/item-standard.php template in your own extension:
https://aimeos.org/docs/latest/admin/jq ... templates/
