How to organize work with the frontend?
АндрейЖидилин
Post by АндрейЖидилин » 29 Apr 2022, 11:43
Hello.
I can not understand how to create a theme and how to work with it?
I created the extension as described in the documentation https://aimeos.org/docs/latest/developer/extensions/
Next, I need a copy of css and ys to be placed in the directory /packages/<my-extension>/themes/client/html/<my-theme>/...
And run composer up
Where can I get these files css and js?
Re: How to organize work with the frontend?
Post by aimeos » 29 Apr 2022, 12:14
АндрейЖидилин
Post by АндрейЖидилин » 29 Apr 2022, 12:38
I copied and run composer up
But in the setting I do not see my theme
I see only Default
What else needs to be done to make the topic appear in the list?
Post by aimeos » 29 Apr 2022, 12:50
Did you create a Laravel theme extension here (not a standard Aimeos extension)?
https://aimeos.org/extensions
АндрейЖидилин
Post by АндрейЖидилин » 29 Apr 2022, 13:52
aimeos wrote: 29 Apr 2022, 12:50 Did you create a Laravel theme extension here (not a standard Aimeos extension)?
Yes, I created an extension and installed via composer
Screen: http://joxi.ru/Q2KdXRjCOGGwRA
Post by aimeos » 29 Apr 2022, 14:42
The ./config/client.php file of the generated extension misses a configuration:
<?php
return [
	'html' => [
		'themes' => [
			'<extensionname>' => '<extensionname>',
	'jsonapi' => [
Please add that to your ./config/client.php file in your extension and replace <extensionname> with the name of your extension.
This is now also fixed in the extension generator so new Laravel theme extensions will contain the necessary code
АндрейЖидилин
Post by АндрейЖидилин » 29 Apr 2022, 15:05
thanks It works
АндрейЖидилин
Post by АндрейЖидилин » 29 Apr 2022, 15:38
Tell me what is the difference between
composer req aimeos-themes/<my-theme>
and
composer req aimeos-extensions/<my-theme>
And what is the right command to use?
Post by aimeos » 29 Apr 2022, 15:47
АндрейЖидилин wrote: 29 Apr 2022, 15:38
This one is correct for 2022.x versions, the documentation for 2022 isn't published yet but will be soon.
АндрейЖидилин
Post by АндрейЖидилин » 30 Apr 2022, 06:18
Okay, I installed the extension, but when I change
/packages/<my-extenshion>/views/base.blade.php
Nothing happens. Changes only when the file is changed
/vendor/aimeos/aimeos-laravel/src/views/base.blade.php
How can I change something without affecting the vendor's code?
