Basket: add same product
heural
Post by heural » 12 Jul 2022, 07:27
Hi Aimeos-Team!
I want to add a product multiple to basket without add the quantity of the order item, but add a new order item.
The reason are designable products within an external editor.
So far I´ve extended the \Aimeos\MShop\Order\Item\Base\Product\Standard with my own impl. with a new column to save the "designable" parameters from the external editor. (https://aimeos.org/docs/latest/models/extend-managers/)
Now I look into the code Aimeos\MShop\Order\Item\Base\Base::addProduct and ::getSameProduct
and there are "getAttributeItems". Can we add attributes to an order-item during the "addProduct" or is these the original attributes from the product? Now I am confused with the extending the manager/item above.
Thx a lot!
Ralf
Thanks a lot!
heural
Re: Basket: add same product
Post by heural » 12 Jul 2022, 08:33
I checked out the compare-Funktion in Aimeos\MShop\Order\Item\Base\Product\Standard and added my new column in my own implementation to the compare-condition and it worked.
Thanks a lot!
Post by aimeos » 13 Jul 2022, 06:53
Instead of storing the design parameters in an additional column, you can also store them in a custom product attribute. Then, products in the basket are also not merged together when they have different attribute values.
