Add new field to users can't show and store the data
amJing
Post by amJing » 01 Sep 2022, 09:18
Hi There,
I followed this article https://aimeos.org/docs/latest/models/e ... /#easy-way to add new field to users,
First I created manager decorator at packages/cywextension/src/MShop/Customer/Manager/Decorator/CywCustomerDecorator.php
<?php
namespace Aimeos\MShop\Customer\Manager\Decorator;
class CywCustomerDecorator extends \Aimeos\MShop\Common\Manager\Decorator\Base
implements \Aimeos\MShop\Common\Manager\Decorator\Iface
    private $attr = [
        'customer_id' => [
            'code' => 'customer.customer_id',
            'internalcode' => 'mcus."customer_id"',
            'label' => 'User customer id',
            'type' => 'integer',
            'internaltype' => \Aimeos\Base\DB\Statement\Base::PARAM_INT,
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
    public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
then change the config in config/shop.php
'mshop' => [
        'customer' => [
            'manager' => [
                'decorators' => [
                    'local' => ['CywCustomerDecorator']
then overwrite the template at packages/cywextension/templates/admin/jqadm/customer/item.php
<div class="col-sm-8">
<?php if( $this->get( 'itemData/.modify' ) ) : ?>
<input class="form-control item-customerid" type="text" required="required" tabindex="1" autocomplete="off"
    name="<?= $enc->attr( $this->formparam( array( 'item', 'customer.customer_id' ) ) ) ?>"
    placeholder="<?= $enc->attr( $this->translate( 'admin', 'Customer ID (required)' ) ) ?>"
    value="<?= $enc->attr( $this->get( 'itemData/customer.customer_id' ) ) ?>"
    <?= $this->site()->readonly( $this->get( 'itemData/customer.siteid' ) ) ?> />
<?php else : ?>
<span class="form-control item-customerid">
    <?= $enc->html( $this->get( 'itemData/customer.customer_id' ) ) ?>
</span>
<?php endif ?>
</div>
BUT, the value for my new field "customer_id" can't show up on page, and when I input a value for "customer_id" and click save button, no error show up, then check DB table, the vlaue doesn't stored.
In order to see if I can get the data, I care decorator for jqadmin at packages/cywextension/src/Admin/JQAdm/Common/Decorator/CywCustomerDecorator.php, the following codes cause some errors :(
namespace Aimeos\Admin\JQAdm\Common\Decorator;
class CywCustomerDecorator extends Base
    public function save() : ?string
        return $this->getClient()->save();
    public function get() : ?string
        $view = $this->object()->data( $this->view() );
		try
			if( ( $id = $view->param( 'id' ) ) === null )
				$msg = $this->context()->translate( 'admin', 'Required parameter "%1$s" is missing' );
				throw new \Aimeos\Admin\JQAdm\Exception( sprintf( $msg, 'id' ) );
			$manager = \Aimeos\MShop::create( $this->context(), 'customer' );
			$view->item = $manager->get( $id, $this->getDomains() );
			// $view->itemData = $this->toArray( $view->item ); // this line has error Called unknown macro "toArray" on class "Aimeos\Admin\JQAdm\Customer\Standard"
			$view->itemBody = parent::get();
            print_r($view->item);
            // print_r($view->itemData);
		catch( \Exception $e )
			$this->report( $e, 'get' );
            dd($e);
            print_r("error=============");
		return $this->render( $view ); // this line has error Called unknown macro "render" on class "Aimeos\Admin\JQAdm\Customer\Standard"
'admin' => [
        'jqadm' => [
            'customer' => [
                'decorators' => [
                    'global' => ['CywCustomerDecorator']
What I have done all listed here, could any one help me to figure out if I missing anything?
Thanks very much for any help!
amJing
Re: Add new field to users can't show and store the data
Post by amJing » 01 Sep 2022, 09:24
I think it's toArray and fromArray issue, so I did the follow things, but it still can't work.
First to add decorator for customer item at packages/cywextension/src/MShop/Customer/Item/Decorator/CywCustomerItemDecorator.php
namespace Aimeos\MShop\Customer\Item;
class CywCustomerItemDecorator extends Standard
    private $myvalues;
    public function __construct(
        \Aimeos\MShop\Common\Item\Address\Iface $address,
        array $values = [],
        array $listItems = [],
        array $refItems = [],
        array $addrItems = [],
        array $propItems = []
        parent::__construct($address, $values, $listItems, $refItems, $addrItems, $propItems);
        print_r($values);exit;
        $this->myvalues = $values;
    public function getCustomerId(): int
        if (isset($this->myvalues['customer_id'])) {
            return (int) $this->myvalues['customer_id'];
        return 0;
    public function setCustomerId(?int $val): \Aimeos\MShop\Common\Item\Iface
        if ((int) $val !== $this->getLocationId()) {
            $this->values['customer_id'] = (int) $val;
            $this->setModified();
        return $this;
    public function fromArray(array &$list, bool $private = false): \Aimeos\MShop\Common\Item\Iface
        $unknown = [];
        $item = parent::fromArray($list, $private);
        foreach ($list as $key => $value) {
            switch ($key) {
                case 'customer_id':
                    $item = $item->setCustomerId($value);
                    break;
                default:
                    continue 2;
            unset($list[$key]);
        return $item;
    public function toArray(bool $private = false): array
        $list = parent::toArray($private);
        print_r('Here is itemmmmmmmmmm+++++++++++++++++');exit; // can't print the value
        if ($private === true) {
            $list['customer_id'] = $this->getCustomerId();
        return $list;
then change config in config/shop.php
'mshop' => [
    'customer' => [
        'item' => [
            'decorators' => [
                'local' => ['CywCustomerItemDecorator']
        'manager' => [
            'decorators' => [
I did research everywhere, but don't know how to move on, please helpppp!! Thanks!!
Post by aimeos » 02 Sep 2022, 10:08
The code must be "customer_id" only, not "customer.customer_id" everywhere because the column is named customer_id and that's exactly what's returned by the database.
