Scheduler: Access denied for user ''@'localhost'
rvhelp
Post by rvhelp » 20 Oct 2022, 11:00
After updating to the latest Aimeos version, this shedular no longer works.
An exception occurred in the driver: SQLSTATE[HY000] [1045] Access denied for user ''@'localhost' (with password: NO).
Local Configuration:
'DB' => [
'Connections' => [
'Default' => [
'charset' => 'utf8',
'dbname' => 'name',
'driver' => 'mysqli',
'host' => 'localhost',
'password' => 'pw',
'port' => 3306,
'user' => 'name',
Re: Scheduler: Access denied for user ''@'localhost'
Post by aimeos » 20 Oct 2022, 15:26
Did you overwrite the Resources/Private/Config/resource.php file in your project-specific Aimeos TYPO3 extension?
rvhelp
Post by rvhelp » 21 Oct 2022, 07:23
No - if i dump $defaultConnection['user'] or 'dbname' in the aimeos resource.php I get the correct database user and database name.
Post by aimeos » 21 Oct 2022, 07:30
Your "plugin.tx_aimeos.settings.resource.email.*" settings cause this problem because they also replace the existing "resource" config subtree. Use the "Advanced Aimeos scheduler" instead, where you can enter e-mail addresses in separate fields.
rvhelp
Post by rvhelp » 21 Oct 2022, 08:43
In the Advanced Planner, there are no tasks in the selection list?
rvhelp
Post by rvhelp » 21 Oct 2022, 09:53
The tasks are missing even if I create a new normal Aimeos task.
Post by aimeos » 21 Oct 2022, 11:05
We don't see that problem in our test installation.
Please check what could be the problem.
rvhelp
Post by rvhelp » 21 Oct 2022, 14:57
Okay, i will try. Could you give me a hint how I could best check this respectively where?
If i disable my plugin extention the list is no longer empty.
Post by aimeos » 24 Oct 2022, 17:24
Maybe your class uses an old method call with is not available any more.
Check the list of breaking changes and adapt your custom code:
https://aimeos.org/docs/latest/changelog/2022.x/
