Footer link change
Footer link change
Hello Dear,
How can i change footer link or add new page link in footer.
Thank You
PHP 7.3
imeos:~2021.10
Thank You
PHP 7.3
imeos:~2021.10
- Screenshot_3.png (15.8 KiB) Viewed 6623 times
Re: Footer link change
Copy the ./vendor/aimeos/aimeos-laravel/src/views/base.blade.php file to ./resources/views/vendor/shop/base.blade.php and adapt that file.
You can also copy it to your own Aimeos theme extension for Laravel if you want to have different themes for each shop:
https://aimeos.org/docs/latest/laravel/ ... -templates
Hi!
I'm using aimeos-laravel 2023-01 and following your instructions worked for changing the base.blade.php, but the problem is I do want to have different themes for each shop. After looking through the documentation, it's still not clear where to put the new base.blade.php...
My extension is under ./packages/(my-extension)/ and then they mention a ./views here that simply isn't there.
can you help me by telling me where I'm suppose to place my new base.blade.php if it will be different for every shop I make.
Thank you very much for your time,
Should the theme be different for each installation (= separate Laravel applications) or in a SaaS setup in one common Laravel application?
In the first case, you only need to copy the ./vendor/aimeos/aimeos-laravel/src/views/base.blade.php file to your ./resources/views/vendor/shop/ directory like described here:
In the second case, you need to create an Aimeos Theme package and adapt the base.blade.php file in that package. When you install the package and select the theme in the Aimeos backend for that SaaS site, it will be used for that site only. More about Laravel theme packages is available here:
https://aimeos.org/docs/latest/laravel/themes/
