Version 16.0.1.1 and Typoscript
trimble
Post by trimble » 07 Feb 2016, 10:46
Hallo,
thanks for the new version. The simplified backend for customers is great.
After the update I have the problem that my typoscript isn't working anymore.
One example: Although I've set
plugin.tx_aimeos.settings.client.html.catalog.stage.default.subparts {
// 0 = image
1 = navigator
2 = breadcrumb
I see the image. In former versions I had no problems. Did the syntax change?
Regards
trimble
Re: Version 16.0.1.1 and Typoscript
Post by aimeos » 07 Feb 2016, 12:01
trimble wrote:thanks for the new version. The simplified backend for customers is great.
That's good to hear :-)
trimble wrote:After the update I have the problem that my typoscript isn't working anymore.
Due to moving the PSR-4, the configuration settings changed and "default" has been replaced by "standard". You can find more information in the upgrade documentation:
https://aimeos.org/docs/TYPO3/Update_Ai ... .x_to_16.x
trimble
Post by trimble » 07 Feb 2016, 21:18
thanks a lot! I missed that point.
Regards
trimble
