add variant to selection product: js error
heural
Post by heural » 12 Apr 2024, 13:09
Hi Aimeos-Team,
I can not add variants to selection products, a js error occured:
ReferenceError: getCss is not defined
(aimeos-typo3: 2023.10.6)
How can I fix that?
Thank you!
Thanks a lot!
Re: add variant to selection product: js error
Post by aimeos » 12 Apr 2024, 18:43
You have overwritten the template of the product section subpart in an earlier versions (before 2023.x) and upgraded to 2023.x without adapting the template to the new JS code for that panel.
The changes are partly described here: https://aimeos.org/docs/latest/changelog/2023.x/
heural
Post by heural » 15 Apr 2024, 08:00
Ok, thats it. Thank you!
Thanks a lot!
