Admin Vue Components
jafo66
Post by jafo66 » 23 Apr 2024, 21:48
I'm looking to copy and implement a similar Vue component like the property-table.js component used in the Customer/property subpanel within the admin screens.
I copied the .js file from within the admin/jqadm/js/components directory and placed it inside of the following trying to see what would work:
- /theme directory of my extension
- /js/components directory of my extension (I created that folder)
- in the /template directory along with the other list.php & item.php files files for the area.
None of those worked so could you let me know where the components should reside?
Thanks!
jafo66
Re: Admin Vue Components
Post by jafo66 » 24 Apr 2024, 02:53
Should I be using this: https://aimeos.org/docs/latest/admin/jqadm/customize/
If so, how do I include all .js files in a directory?
Post by aimeos » 25 Apr 2024, 07:21
You have to add all new files to the manifest.jsb2 file of your extensions like explained in the article you've linked. Only the custom.js file is automatically included.
