Implement HTML frontend
dugz1611
Post by dugz1611 » 04 Oct 2024, 08:27
php -v 8.1.12
Aimeos version - 2023/10
Good day
I have an HTML template I'd like to implement on the front end instead of using the current Aimeos one, what do I need to do after creating the extension, also I intend to keep the Aimeos admin backend as is, please assist (I am using the multi-shop functionality)
Kind regards
Re: Implement HTML frontend
Post by aimeos » 04 Oct 2024, 10:54
If you want to change the HTML structure of the Aimeos components, you have to copy and change the templates:
https://aimeos.org/docs/latest/frontend ... templates/
If you want to create an installable theme for Laravel, also read this article:
https://aimeos.org/docs/latest/laravel/themes/
