Trouble Displaying Selected Value for Custom Columns in jqadmin Template
PaoloLegaspi
Post by PaoloLegaspi » 25 Nov 2024, 16:22
I’m customizing the product_item jqadmin template to include some additional values. The code successfully updates the new columns, but the selected value doesn’t show up in the dropdown. I checked itemData, and it doesn’t seem to include the new columns.
Any ideas on what I might be missing? Do I have to extend the jqadmin/product/standard? I think this involves the toArray and fromArray
Dropdown
<div class="form-group row optional advanced">
                    <label class="col-sm-4 form-control-label help"><?= $enc->html( $this->translate( 'admin', 'Is Testdrive' ) ) ?</label>
                                <div class="col-sm-8">
                                    <select class="form-select item-isTestdrive" tabindex="1"
                                        name="<?= $enc->attr( $this->formparam( array( 'item', 'is_testdrive' ) ) ) ?>"
                                        v-bind:readonly="!can('change')" >
                                        <option value="">
					<?= $enc->html( $this->translate( 'admin', 'Please select' ) ) ?>
						</option>
                                        <option value="0" <?= $selected( $this->get( 'itemData/product.is_testdrive'), 0 ) ?> >
                                            <?= $enc->html( $this->translate( 'mshop/code', 'No' ) ) ?>
                                        </option>
                                        <option value="1" <?= $selected( $this->get( 'itemData/product.is_testdrive'), 1 ) ?> >
						<?= $enc->html( $this->translate( 'mshop/code', 'Yes' ) ) ?>
					</option>
                                    </select>
                                </div>
                                <div class="col-sm-12 form-text text-muted help-text">
                                    <?= $enc->html( $this->translate( 'admin', 'Is this product a testdrive?' ) ) ?>
                                </div>
                            </div>
Product Manager Decorator
class ProductDecorator extends \Aimeos\MShop\Common\Manager\Decorator\Base
    private $attr = [
        'is_testdrive' => [
            'code' => 'product.is_testdrive',
            'internalcode' => 'mpro."is_testdrive"',
            'label' => 'Is Test Drive',
            'type' => 'bool',
        'location' => [
            'code' => 'product.location',
            'internalcode' => 'mpro."location"',
            'label' => 'Location',
            'type' => 'string',
     * @return array
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
     * @param bool $withsub
     * @return array|\Aimeos\Base\Criteria\Attribute\Iface[]
    public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
AppServiceProvider
public function boot()
        \Aimeos\MShop\Product\Item\Standard::macro( 'getIsTestdrive', function() {
            return $this->get( 'product.is_testdrive' );
        \Aimeos\MShop\Product\Item\Standard::macro( 'getLocation', function() {
            return $this->get( 'product.location' );
        \Aimeos\MShop\Product\Item\Standard::macro( 'setIsTestDrive', function( $value ) {
            return $this->set( 'product.is_testdrive', (int) $value );
        \Aimeos\MShop\Product\Item\Standard::macro( 'setLocation', function( $value ) {
            return $this->set( 'product.location', (string) $value );
Re: Trouble Displaying Selected Value for Custom Columns in jqadmin Template
Post by aimeos » 27 Nov 2024, 14:06
Can you check if this works:
    private $attr = [
        'product.is_testdrive' => [
            'internalcode' => 'is_testdrive',
            'type' => 'bool',
        'product.location' => [
            'internalcode' => 'location',
See: https://aimeos.org/docs/latest/models/e ... -decorator
