Extend Model/Manager, Query has syntax error (missing ,)
Hi Aimeos-Team,
with the upgrade from 2023 -> 2024 i have some trouble with the queries, e.g. in the Dashboard.
I have extended the order model (added 3 attributes/columns: order.customexported, order.customcustomerid, order.customusername) - thats worked in 2023 so far:
Now in 2024 (2024.10.x-dev), there are some missing "," next to my custom-fields.
Thank you for your support!
Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'mord."id" AS "order.id", mord."channel" AS "order.channel",
mord."siteid...' at line 2:
SELECT mord."id" AS "order.id", mord."siteid" AS "order.siteid", mord."ctime" AS "order.ctime", mord."mtime" AS "order.mtime", mord."editor" AS "order.editor", mord."invoiceno" AS "order.invoiceno", mord."relatedid" AS "order.relatedid", mord."channel" AS "order.channel", mord."datepayment" AS "order.datepayment", mord."datedelivery" AS "order.datedelivery", mord."statusdelivery" AS "order.statusdelivery", mord."statuspayment" AS "order.statuspayment", mord."customerid" AS "order.customerid", mord."customerref" AS "order.customerref", mord."comment" AS "order.comment", mord."sitecode" AS "order.sitecode", mord."langid" AS "order.languageid", mord."currencyid" AS "order.currencyid", mord."price" AS "order.price", mord."costs" AS "order.costs", mord."rebate" AS "order.rebate", mord."tax" AS "order.taxvalue", mord."taxflag" AS "order.taxflag", mord."cdate" AS "order.cdate", mord."cmonth" AS "order.cmonth", mord."cweek" AS "order.cweek", mord."cwday" AS "order.cwday", mord."chour" AS "order.chour", mord."customexported" AS "order.customexported", mord."customcustomerid" AS "order.customcustomerid", mord."customusername" AS "order.customusername"
mord."siteid" AS "order.siteid", mord."invoiceno" AS "order.invoiceno",
mord."statuspayment" AS "order.statuspayment", mord."statusdelivery" AS "order.statusdelivery",
mord."sitecode" AS "order.sitecode", mord."customerid" AS "order.customerid",
mord."taxflag" AS "order.taxflag", mord."customerref" AS "order.customerref",
mord."comment" AS "order.comment", mord."ctime" AS "order.ctime",
FROM "mshop_order" mord
LEFT JOIN "mshop_order_product" AS mordpr ON ( mord."id" = mordpr."parentid" )
WHERE ( ( mord."siteid" IN ('','1.') AND mordpr."siteid" IN ('','1.') ) AND ( mordpr."siteid" IN ('','1.') ) )
GROUP BY mord."id", mord."siteid", mord."ctime", mord."mtime", mord."editor", mord."invoiceno", mord."relatedid", mord."channel", mord."datepayment", mord."datedelivery", mord."statusdelivery", mord."statuspayment", mord."customerid", mord."customerref", mord."comment", mord."sitecode", mord."langid", mord."currencyid", mord."price", mord."costs", mord."rebate", mord."tax", mord."taxflag", mord."cdate", mord."cmonth", mord."cweek", mord."cwday", mord."chour", mord."customexported", mord."customcustomerid", mord."customusername" mord."id"
ORDER BY mord."ctime" DESC, mord."id" DESC
LIMIT 10 OFFSET 0Thank you for your support!
Thanks a lot!
Re: Extend Model/Manager, Query has syntax error (missing ,)
Check if your code and search configuration looks like this and remove any overwritten SQL for the managers:
https://aimeos.org/docs/latest/models/e ... /#easy-way
Yes I have (the "custom way"),
the only "overwritten" for "SQL-like" is the saveItem-Func. Do I dont need this anymore?
btw in the docu:
should be this ?
btw in the docu:
public function getSearchAttributes( bool $withsub = true ) : array
return parent::getSearchAttributes( $withsub ) + $this->createAttributes( $this->attr );
return parent::getSearchAttributes( $withsub ) + $this->createAttributes( $this->searchConfig);
}Thanks a lot!
It's not needed any more. We've update the article in the docs accordingly.heural wrote: 19 Dec 2024, 15:22 Yes I have (the "custom way"),
