Multi-Shops - templates
heural
Post by heural » 17 Jan 2025, 08:44
Hi Aimeos-Team,
is there a way to use different templates for multi-shop scenario?
Thank you!
Thanks a lot!
Re: Multi-Shops - templates
Post by aimeos » 17 Jan 2025, 09:23
Yes, in Laravel based Aimeos shops, you can assign different themes to the sites:
https://aimeos.org/docs/latest/laravel/themes/
In TYPO3, you add use TypoScript to the page tree to use a different settings for the fs-theme virtual filesystem:
https://github.com/aimeos/aimeos-typo3/ ... hp#L58-L63
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 17 Jan 2025, 09:28
Hello! I am not from the development team, we are also studying this system on our own.
You can add your own theme to each individual store (supplier) + separate settings (color and dimension of images)
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
heural
Post by heural » 17 Jan 2025, 12:18
Thank you both, but I expressed too imprecisely. I mean the php templates in templates/client/html.
Thanks a lot!
Post by aimeos » 18 Jan 2025, 12:10
This works when using several Aimeos theme packages for Laravel. Then, you can have different PHP templates too.
heural
Post by heural » 20 Jan 2025, 14:15
But there is no way to do this for TYPO3?
Thanks a lot!
Post by aimeos » 21 Jan 2025, 10:59
Not at the moment but it would be possible if we add a configuration option for that and add the theme name as second argument to all getTemplatePaths() calls here:
https://github.com/aimeos/aimeos-typo3/ ... er/Classes
heural
Post by heural » 21 Jan 2025, 13:49
That would be very nice!
I have found a way (hack ;-)) for frontend in Aimeos\Aimeos\Base\View.php before https://github.com/aimeos/aimeos-typo3/ ... ew.php#L51
I have a created my own View.php (like here: https://aimeos.org/docs/latest/typo3/ex ... se-classes)
and changed the template path for the specific extension and theme (shop1,shop2...):
        foreach($templatePaths as $path => $templatePath) {
            /* multi shop template
            * $config['settings']['theme'] e.g. "shop1" or "shop2"
            * (typoscript: plugin.tx_aimeos.settings.theme)
            if (stripos($path, 'aimeos_custom') !== false && isset($config['settings']['theme'])) {
                $templatePaths[$path] = str_replace('templates/client/html', 'templates/'.$config['settings']['theme'].'/client/html', $templatePath);
Thanks a lot!
