Adding Mollie Payment Gateway to AImeos
saniul
Post by saniul » 29 Jun 2021, 05:47
we are using aimeos 19 version and laravel 7 in linux OS.
Can you please suggest how easily we can add the mollie payment gateway into the system. It will be great if you show us the required steps to follow. can we just configure it from admin panel only ?
Re: Adding Mollie Payment Gateway to AImeos
Post by aimeos » 29 Jun 2021, 06:11
You need to install the ai-payments extension and configure a payment service option for Mollie:
https://aimeos.org/docs/2021.x/manual/services/#mollie
Please note that Laravel 7 isn't supported any more and probably contains security issues:
https://laravel.com/docs/8.x/releases#support-policy
Also, Aimeos 2019.10 is in ETLS phase:
https://aimeos.org/roadmap
It's only supported by the Aimeos GmbH if you have bought their extended long term support:
https://aimeos.com/support#c428
