Aimeos profile change fields
we've been setting up a shop with typo3 and aimeos for our internal team and as such, we don't need some fields in the aimeos profile plugin when creating an account, but others that are not listed instead, as well as removing the delivery address part entirely.
As such, we were wondering whether it is possible to change the fields that are saved on the forms as well as in the database.
As seen in attachments.
typo3-version: 11.5.10
php-version: 8.1.2
aimeos-version: 22.7.1
php-version: 8.1.2
- NNO.png (26.41 KiB) Viewed 8381 times
Re: Aimeos profile change fields
To add new fields to the database, please read this article:
https://aimeos.org/docs/latest/models/extend-managers/
How to overwrite the templates is described here:
https://aimeos.org/docs/latest/frontend ... templates/
Account Profile component:
https://aimeos.org/docs/latest/frontend ... s/#profile
Hey, first of all thanks for answering.
we've tried the following in our extension constants:
we've tried it with and without, with .php and without, it doesn't really seem to affect the frontend.
Thanks for the help and best regards!
plugin.tx_aimeos.settings.client.html.account.profile.body = fileadmin/templates/frontend/account/profile/body
plugin.tx_aimeos.settings.client.html.account.profile.template-body = fileadmin/templates/client/html/account/profile/body.phpCode: Select all
plugin.tx_aimeosThanks for the help and best regards!
That doesn't work. Instead, create a new Aimeos extension for TYPO3 and store you copied templates there:
- https://aimeos.org/docs/latest/frontend ... templates/
